New codes!!!! Someone help
10-02-2020, 11:29 AM | #1 |
Rep 20
Ok guys so I just replaced my fuel pump regulator! It's still throwing these codes
•9319 KOMBI - Fuel level sensor, left •6295 EKPS - No control current. System: fuel pump There was another code that was under the ECK that had something to do with engine plausibility. Someone help!! I noticed I had a crack in my coolant tank reservoir so that's causing the leak so I'm replacing it now!! What do these other codes mean? 2008 328i E90 |
10-02-2020, 11:43 AM | #2 |
Rep 2,203
Was the repair done by a shop? I'd take it back to them if so.
If not DIY? check fuses as yet?
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
10-02-2020, 12:29 PM | #4 |
Rep 20
No it wasn't done by a shop & yes I did it myself. I didn't change the fuel pump, I changed the regulator because it was spewing gas everywhere! Then it started showing the left fuel level sensor code. Now it still shows that code alone with the ones I just posted. Checked under my hood after hearing a pop & smelling coolant & smoke & I noticed my coolant tank reservoir had a crack in it. So I'm replacing it now
10-02-2020, 12:42 PM | #5 | |
Rep 2,203
It would be great if you had INPA/ ista to grab some data if any.
10-02-2020, 07:11 PM | #6 | ||
Rep 20
10-03-2020, 01:43 PM | #7 | |
Rep 2,203
