E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > swapping the HPFP from F30 to E90....
Reply
      10-07-2020, 09:39 PM   #1
Glene
Drives: 335is
Bought a used 2013 F30 N55 engine for my 2011 E90 335Xi. When swapping HPFP over, I noticed they are not the same. After I removed 5 5mm hex bolts and tried to separate the HPFP housing from the vacuum pump, it has high resistance so I stopped. did anyone do this swapping before?
      10-08-2020, 07:01 AM   #2
Smgs1992
Drives: 2007 bmw 335i
Youre gonna find that the F30 uses an electronic wastegate while E90 uses pneumatic
07 E92 335i 6MT, MMP inlets, DCI, VRSF 7.5 competition intercooler, VRSF catless downpipes, VRSF chargepipe, 335is clutch, Vader Solutions stage 2 LPFP, MHD stage 2+, Hawk HPS 5.0 pads, R1 Concepts drilled slotted rotors, TSW Nurburgring 19x8 19x9.5
      10-08-2020, 09:14 AM   #3
Glene
Drives: 335is
Engine does not come with the turbo. If I use the spark plugs and fuel injector that came with the F30 engine, does it set codes?
      10-12-2020, 09:57 AM   #4
Glene
Drives: 335is
Update: You can't just swap the hpfp. The vacuum pump also needs to be swapped. It sucks that you have to open up the vacuum pump plastic seal in order to remove the vacuum pump. BMW requires to use the special tool, but I did it without it.
Reply
e90post
