Water pump on ramps?
10-08-2020, 08:16 PM | #1 |
Rep 109
Have any of you guys replaced the water pump and t-stat with the car on ramps? I know most people replace them with the car on jack stands but just wondering how difficult it would be with just ramps.
The reason I ask is I already have the coolant and oil drained as I’m doing the ohfg, the radiator out for the belt replacement, and the intake manifold off to do a walnut blast. Don’t really wanna put everything back together just to drive the car off the ramp and go onto jacks. Thanks Car is an 08 e92 335xi Last edited by 2008E92335XI; 10-08-2020 at 08:22 PM.. |
10-08-2020, 08:59 PM | #3 |
Rep 17
yeah no need to remove the subframe but radiator fan removal is necessary also need to loosen front sway bar.
to answer the original question , imo, as long as u can get the rear of the vehicle up to a right height were the vehicle is level it should be fine. |
10-08-2020, 09:10 PM | #4 |
Rep 873
Your front end is already in the air so it should be very easy to get a jack under the centre jack point to lift the car off the ramps and set it down onto jack stands. Depending on your jack you may have to use a block for a little extra height to clear the ramps but you don't have to have the car running.
10-08-2020, 10:45 PM | #5 |
Rep 2,758
It would be no problem on a RWD car but on the xi it might be more difficult. There is less room with the subframe being larger on the Xi's so might not have all the room you need
10-09-2020, 07:54 AM | #6 |
Rep 288
I have replaced several water pump's and t-stat's just by jacking the car up high enough and putting it on jack stands it took me maybe two hour's max with the bleed process also....
The usual mods....
10-09-2020, 08:26 AM | #7 |
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
Xi cars are a lot more work to replace the WP on. You don't need to drop the subframe but it makes the job way easier once it's dropped.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
10-09-2020, 08:48 PM | #9 |
Rep 109
Thanks all
Do you have any suggestions on how to get the car off the ramps and on to jack stands. The car is currently up 12 inches off the ground. Thanks |
10-09-2020, 11:05 PM | #10 | |
Zeed
17
Rep 561
10-10-2020, 05:38 AM | #11 | |
Rep 109
Do you mind sharing what steps you used to complete the job? |
10-10-2020, 09:45 AM | #12 | ||
Rep 6,968
Drives: 2007 Black/Black 335i e90
The only thing I'd do differently would be to take the FMIC out & the radiator fan out, which gives you a lot more room to work. |
10-10-2020, 03:09 PM | #13 |
Art Collector
2427
Rep 3,450
If you want to use jack stands (which will give you more room to manoeuvre near the wheel well), just put a floor jack underneath the center jacking point, lift, remove ramps, put in jack stands. Easy.
10-10-2020, 03:52 PM | #14 | |
Rep 4,330
as it's already high in the air you're probably going to need some blocking between the car and the jack. |
10-10-2020, 11:53 PM | #15 | |
Rep 7,215
I've done two on ramps FWIW. One RWD and one XI. You don't need to drop the subframe... |
