E92 Replacing rusted rear license plate bracket
10-10-2020, 06:25 PM | #1 |
Rep 63
Hi.
My stock rear license plate bracket rusted at the nails sites. I'm looking for a replacement that's not over-priced at the dealer. Amazon has many listings but there are concerns that the "stainless steel nails" and "brass washers" rust after a few months. [update] This bracket is specific to this model... since the bracket bolts in the middle and mounts the license plate on the bracket itself, not the car....German Engineering... Last edited by soulcrusher; 10-11-2020 at 03:12 PM.. |
10-11-2020, 03:28 PM | #3 |
Rep 135
I couldn’t find anything decent besides original OEM. I ran into the same issue reading reviews on Amazon. Tried eBay for lightly used parts but they were all rusted away and cost almost the same as new from FCP.
10-12-2020, 06:05 AM | #4 | |
Rep 18,801
When you say "rusted at the nails sites", does that mean the threaded screw holes? BMW updated the part, it looks like they got rid of the metal screw hole bungs and now just have plastic that uses a automotive-use course thread screw. To prevent rust issues, I use stainless steel hardware for mounting license plates on my BMWs. Learned that lesson long long ago.
StradaRedlands4998.50 |
10-12-2020, 05:13 PM | #5 | |
Rep 135
https://www.e92n55.com/2017/05/how-t...late-hardware/ |
Mike K332.00 |
10-13-2020, 09:24 AM | #6 | |
Rep 18,801
Most license plates are stamped aluminum nowadays, galvanic reaction between iron fasteners and aluminum promote corrosion on the fastener, which is why I switched to stainless some 30 years ago. Thanks for posting the link. |
10-13-2020, 09:47 AM | #7 |
Rep 13
I had to replace mine (when I bought the car I had to yank off the original BMW one and the plate) and ended up just using a generic one from Advance Auto Parts for ~$10 with some washers to make sure the bracket was held in tight. I tried to buy a BMW-like one from Amazon which arrived yesterday and the screws didn't even go in tight...
10-13-2020, 12:08 PM | #8 | |
Rep 26
07-16-2022, 10:24 AM | #9 |
Rep 1
Stubborn License Plate Screws
I got a snappy new license plate after registering at the DMZ in Florida yesterday and was really excited to install the new plate so I could be legally compliant (out of state plates have expired). I thought, "Four phillips screws - this will be quick and easy!" After 15 minutes of watching the screws whirl around, but not unscrew, I was about to rip the entire plate assembly off the car. Fortunately, mty wife suggested we just go to happy hour instead. She is wise...
This morning I've been scouring Google for insight into how to remove the screws - preferably without using a crowbar to rip off the entire assembly. Not finding anything - all the videos show folks screwing on new plates, but they neglect to cover the removal process. Any tips for the removal process? |
07-16-2022, 10:44 AM | #10 | |
Rep 3,053
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
Love it! |
07-16-2022, 07:42 PM | #11 |
Rep 769
Good luck in the Florida Demilitarized Zone. I hear it's hell down there what with the stray artillery shells from behind the combatants lines and roving bands of marauders.
Sometimes a bolt is just a bolt.
07-17-2022, 01:32 AM | #12 | |
Rep 780
I did this with my temp plate recently. I bought a "license plate kit" from oreilys. It was like $4, it's basically 4 square plastic grommet things. I marked and drilled the deck lid and squared out the holes with a square file. Popped in the grommets and put put on the plate. There are 3 reasons I did it this way. 1) it was faster, don't have to go to BMW, and could get it done that night (I'm impatient). 2) it was cheaper, the cost was 1/2 of what the gas would have cost just to go get it. (Admittedly the cost was the least concern.) 3) the stock bracket has 2 mounting and vibrates A LOT! Especially if I have the bass turned up. This has 4 points of attachment and has no vibration noise (the most important). |
07-17-2022, 03:09 PM | #13 | |
Rep 2,835
I've had bad brackets on both the wife's and my car. But you cut off the plastic square on the back, pop the "nut" out, drill it and cut the square out. Pop new license plate grommets into place, put a little 3m tape on the back with the skin still on onside to protect the paint and done. I had to cut the new screws down by 1/4" to keep them from being too long. But the whole process just took me less than 20 minutes. |
07-18-2022, 12:07 AM | #14 |
Rep 780
As stated I did it because the bracket only has 2 mounting points to the deck lid and vibrates. Now it doesn't.
What I don't understand is why does mounting a license plate like 95% of manufactures make you cringe? Because it's not the "BMW way"? We basically did the exact same thing except mine I don't have to worry about vibrating. |
