Bsd faults help
10-11-2020, 03:51 AM | #1 |
Rep 9
Bsd faults help
Hello I got an N54 and am having bsd issues and not sure what the problem is, says i got missing ibs sensor and water pump missing even though I just changed the water pump and tstat but I don’t even think it was the problem. Definitely a bsd problem any thoughts?
10-11-2020, 08:01 AM | #2 |
Rep 3,924
Unplug the IBS, and see what codes return after clearing them.
BSD line codes could be the device mentioned in the code failing, or another device on the line failing and causing an error somewhere else. You need to selectively unplug and replug devices while reading/clearing codes in order to figure out which item(s) are actually failing. |
10-11-2020, 08:04 AM | #3 |
Rep 1,272
The BSD consumers are IBS, WP, alternator, and oil level sensor. When one takes a crap, it offlines the others.
Unplug one at a time to isolate the defect. |
10-11-2020, 12:14 PM | #5 |
Rep 9
since under voltage and a recent replacement of the water pump could it be the off brand alternator that the guy before me put in? and throwing all them off? since I was getting these codes prior to installing the wp. Also the codes only come back after a 50 miles or so
10-11-2020, 12:17 PM | #6 | |
Rep 9
10-11-2020, 12:23 PM | #7 |
Rep 13,128
Maybe your water pump is just bad.
You could run the purge procedure to see if it works. And if it is bad you shouldn't be driving the car. |
10-11-2020, 01:00 PM | #8 |
Rep 9
No I don’t think water pump because I did the bleed procedure, just like the oem pump I had in when I got the car but I took it to some bmw shit shop and told me to replace a whole list of things to try n jip me. I read the codes and replaced the water pump because of these bsd codes despite the original water pump doing the bleed procedure as well. So both pumps were/are capable of bleeding and they sound fine.
10-11-2020, 03:03 PM | #10 | |
Robot
1696
Rep 2,195
10-11-2020, 05:32 PM | #11 |
Rep 818
Yeah those BSD are a pain.. I was getting them and ended up being the coils.. It only did it when it warmed up and most of the time it shut down charge from the alternator; once it tried to kill the car spiking voltage to 18.5v. My point is most would say it was bad alternator but changing coils stopped issues 5k miles ago.. At least your issue is pointing to a bad part. Good luck.
