10-11-2020, 02:59 PM | #1 |
Rep 525
Coilovers fitted....how to set the ride heights properly?
So....before my car goes in for alignment, i've been trying to get the ride heights sorted.
I'm aware that adjusting the RR for example would have an effect on the FL. Even so, the rears are reasonably equal with the same threads both sides. I also understand that cross weight adjustments would mean bespoke settings - at the moment i just want to get the car riding the same height as stock, maybe just 10mm lower. It all seems to be a mess. I've been measuring from top of the wheel arch to the wheel rim edge. The measurements vary all round, from 8.5cm to 9.5cm, i've got it to a level where it's roughly the same each corner, but what i don't understand is why my FL has had to be set sooooooo much lower than my FR....see the pics below. Doesn't make any sense to me. I have checked that both are sitting at the same level in the knuckle. Any ideas what's going on here? Below pics show how far down they are protruding past the knuckle - as you can see, pretty much bang on the same as you'd expect: |
10-11-2020, 04:56 PM | #2 |
Rep 1,239
Sounds stupid but do all the numbers match (bar the left and right designation)
I personally set them normally the same across the axle. Leave it a week or so of daily driving. Once everything is settled i take some sizes, I prefer to measure from the wheel arch to middle of the centre cap, this takes out any tyre wear ect ect. I dont tend to care much about the difference in threads showing ect ect but yours does seem more than id think there should be. I wouldn’t be overly worried about it. I do have to ask the question why you went down the coil over route if your not looking to drop the height much if any, issue with coil overs the dampers are valved to normally work right about in the middle of the height setting, and anything out of that they arnt optimal for the springs and vice versa... If your really wanting to get the most out of them id take it to a local motorsport suspension place and get them to corner weigh the car and set the ride height & alignment. There will be a trade off between height and ballance but seeing as im going to assume you just want the car to handle better it should be very slight ( IE your not going to the motorsport extream of having mass amounts of rake on the car) |
10-12-2020, 03:24 PM | #3 |
Rep 1,649
I have noticed on several spring swaps that the front left seems to naturally sit higher on these cars. For example, my current set up has even height across the rear but the FL is about 1/4" higher than the FR. Lots of different speculation on the board as to why. In the end, I agree with the other post above. Go to a good shop and have them corner balance it if you are concerned about performance. But if you just want it to look level, then go for what you find you like best.
10-14-2020, 03:34 AM | #4 |
Rep 8,509
Getting the ride heights even can be a pain.
Center Gravity (yes, spelled correctly) are in Atherstone which is only 40 minutes drive from Leicester. They do all my suspension work and I'd certainly recommend them to complete your install/set-up : ride heights, corner weighting and alignment.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
10-14-2020, 05:27 AM | #5 | |
Rep 525
thanks, yeh i did email them but spat out my proverbial coffee when i saw the quote. I've found a local place only 5 miles from me that runs mx5 race cars that can do the alignment + corner weighting for £200-£250 region so giving them a shot, see how it goes. other places around me are: northampton motorsport rogue motorsport mg motorsport in ripley all charge roughly the same, all can do corner weighting etc, but all about 30-40 miles from me. |
10-14-2020, 06:00 AM | #6 | |
Rep 525
measurements - it's currently on (in cm) FL 8.8 FR 8.9 RL 8.7 RR 8.9 stock rideheights were F 9.9 R 10.2 rear tyres are maybe 1.5-2mm more worn than fronts so in that respect i've taken out the rake...and therefore presumably shifted the weight balance rearward. yes originally i wasn't fussed about lowering but now that (accidentally) i lowered the car by 10mm i actually like the aesthetics now! so i'm happy to keep it there without it being impractical. it's the fact that they're all within 2mm of each other which is why i'm concerned about that FL difference... its going to a specialist place tomorrow, i'm excited to see the data and weightings! Last edited by gippy; 10-14-2020 at 07:12 AM.. |
10-14-2020, 01:55 PM | #7 | |
Rep 8,509
With such a difference in the preloads (as per your photos) you may well get some uneven ride/handling characteristics in the car. It's one of the reasons that I opted for Ohlins - the damper bodies have a threaded collar which allows the ride height to be easily and precisely adjusted independently of the preload. Preload should be set first (according to the manufacturer's recommendations), then adjust the ride height by moving the damper bodies in the hub carrier. It looks like you're trying to set the damper bodies at a constant height (relative to the hub carrier) first, and then adjusting the ride height by using the spring preload adjusters. This is not the correct method.
10-14-2020, 06:22 PM | #8 | ||
Rep 1,934
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
10-15-2020, 09:13 AM | #9 |
Rep 8,509
These YouTube videos both relate to adjusting the ride height of coilovers. Neither relate to BMW, and both vehicles are using coilovers which have threaded collars on the lower damper bodies (as does Ohlins R&T), BUT, there are two key messages :
Adjusting ride height by adjusting the spring preload is NOT the way to go.
10-15-2020, 10:53 AM | #10 | |
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
There was just a discussion about this in the past two weeks on this in the F8x forum.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
10-15-2020, 12:51 PM | #11 |
Rep 8,509
There are several different things being discussed in that thread and in the attached installation guides / web articles.
For McPherson struts, spring preload is exactly that - a preloaded spring. This is set when the damper is at its fully extended range, typically after the strut assembly has been built but prior to fitting to the vehicle - if fitted to the vehicle, we let the suspension go into full droop. The damper manufacturer should publish its recommended preload for each specific vehicle, and it's typically expressed in mm compression of the spring from 'slack' i.e. zero load. This is the state when the lower collar is just snug to the spring, i.e. the collar stops rotating under finger pressure, but no further rotation of the collar has been applied. If the preload isn't set before the weight of the vehicle is applied through the strut, then it's guesswork. Raising the lower spring collar would simply jack-up the corner of the car and would keep going until the damper hit its internal stops i.e. its fully extended position. It would then be possible to apply an additional loading to the already loaded spring, but the starting point is incorrect as the spring is already partially compressed - we would be post-loading the spring, not preloading it. The ride height of the vehicle would also have been ruined. As one of the articles makes clear, preload and spring rate are not related. Although preload places the spring into a pre-compressed state, it's rate of deflection rate won't change once the preload has been overcome. If a spring with a 200lb/in rate is preloaded by 1" and a 200lb weight is placed on it, the spring won't compress. Add a further 200lb (a total of 400lb) and it will compress by 1", assuming it's a linear rate spring. Place a 400lb weight on a 200lb/in spring which has not been preloaded, and the spring will compress by 2". Obviously this doesn't apply to the rear suspension on the F3X because the springs are inboard of the damper. It's impossible to have preload in the true sense. For those dampers/struts that have them, independent mechanisms for achieving preload adjustment and ride height adjustment exist for a good reason. If Bilstein dampers require a preload, and the OP had correctly set the preload, and the OP then used the lower spring collars to adjust the ride height (his photos show quite a big difference in the height of the lower spring collars), the correct preload adjustment has been lost, the ride may be compromised, and there's a risk of 'spring blocking' under large primary ride inputs.
10-15-2020, 04:07 PM | #12 | |
Rep 525
So i initially set all the collars high i.e. with all the springs reasonably compressed (and certainly higher than where they were set out the box) so, when i dropped the car to the ground for the first time, it was sat a fair bit higher than stock. Then i started adjusting down. you're absolutely right though and i totally get what you're saying (see below). Anyway it's all sorted and perfect, my FL was a bit low when taking measurements of the ride height in a more logical way i.e. from the bottom sill of the car around the jacking point to the ground. EDIT - i just found this nugget of info on the bilstein website..........i just need to find out what that identified bilstein range is, where the spring is already under some specified preload. (edit...found it) Last edited by gippy; 10-15-2020 at 04:52 PM.. |
10-15-2020, 04:46 PM | #13 |
Rep 525
Watsey
i should have read the instructions more carefully in conclusion, as long as my collar is set somewhere between 215mm to 235mm from spring plate to the kuckle bolt, i'm good |
10-16-2020, 03:32 AM | #14 |
Rep 8,509
gippy guys don't read instructions, but sometimes it's better if we do
The table which you've posted is (obviously) key. Glad to hear that it's all sorted and you're happy with how the car is sitting
