Is 4k Reasonable Pricing for Injectors/Valve Cover?
10-15-2020, 10:32 AM | #1 |
Rep 124
Wanting to get a bit of a sanity check on a repair quote for my 2008 n54 335i. It's been running a little rough (particularly at idle and when cold) the last year or so, and has been throwing a CEL with fuel mixture control codes that keep coming back. I've also been starting to smell a burning oil and strongly suspect valve cover gasket (I've already previously done oil pan and oil filter housing gaskets and the turbos only have 45k or so on them).
Is this a reasonable quote for plugs, valve cover, and injectors? Labor $1209 Fuel Injector $345*6 = $2070 Fuel Injector Clip $12*6 = $72 Spark Plug $25*6 = $150 Valve Cover with Gasket $600 Subtotal $4101 As a side note, thoughts on if it's worth it to put this kind of money into a 2008 car with 105k miles on it... I do have a worry that this sort of cost will just keep continuing (both fuel pumps are original still for instance). I have already done water pump+tstat, oil pan gasket, oil filter housing gasket, both front window regulators, and coils. Suspension is also still original with 105k miles on it... I suppose I'm feeling a bit torn. I love this car but man... it's a money pit. |
10-15-2020, 10:52 AM | #2 |
Rep 818
Yeah if you don't diy or have a money tree in the back. I would cut my losses. It still have ok value now but since bmw is taking away diy'er tools to work on these cars, that value is going to drop soon.
But for the qoute, I think the labor is excessive as is the valve cover cost, but that might save you 700 shopping around other shops and a set of injectors are no more than 1300... So reasonably you are still looking at 2500, a good chuck of change.. I see in the future that shops are going to charge more for repairs on these for the reason stated above, more demand.. So you have to take that into consideration also. Last edited by Tunafish; 10-15-2020 at 11:00 AM.. |
10-15-2020, 11:39 AM | #4 |
Rep 733
$4000 is about what my friend paid to have all of that done on his
Five months later he's doing turbos at 80k, I think he's totalled 6 or 7k into the car by now, which is fine if you're committed to keeping it, but otherwise... you could buy a whole e90 for that. |
10-15-2020, 11:43 AM | #5 |
Rep 4,203
Drives: '11 335is | '16 Macan Turbo
Hell.
No. Ya if you're not willing to diy, then you may want to look for something else to dd
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
10-15-2020, 12:09 PM | #6 |
Rep 16
They are charging a service/fee charge on materials cost, as others already pointed out the materials are cheaper than they have listed.
Ask for labor hours estimated in that quote. It looks to be about 9.5 hours based on $125 marked up hourly rate. I really don't see how this is more than 5 hours of work but I do not know the BMW book hours for the job and they likely charge according to book. |
10-15-2020, 12:16 PM | #7 |
Rep 946
How skilled are you with a set of tools? All that work is pretty much in the same area on top of the engine and aside from needing a couple tools you’d need to order it is a fairly easy diy on a weekend/day off
07 E92 335i 6MT, MMP inlets, DCI, VRSF 7.5 competition intercooler, VRSF catless downpipes, VRSF chargepipe, 335is clutch, Vader Solutions stage 2 LPFP, MHD stage 2+, Hawk HPS 5.0 pads, R1 Concepts drilled slotted rotors, TSW Nurburgring 19x8 19x9.5
10-15-2020, 12:17 PM | #8 |
Rep 5,016
Everyone charges by the book. That’s the way the world works.
Sell it to someone that can DIY with full disclosure and put the $5k you get towards a Lexus. |
10-15-2020, 12:18 PM | #9 |
Rep 946
It’s a 6MT it’ll sell for more than 5k
10-15-2020, 12:57 PM | #10 |
Art Collector
2427
Rep 3,450
I've never understood why people are so quick to base their maintenance decisions on the "value" of their car. I'm not saying that shouldn't be a factor, but it often seems like the first thing people jump to. Sure I understand that it doesn't always make sense to pour loads of money into a car that is worth very little, but at the same time, this is common stuff for N54/N55, is it not? It isn't like OP is talking about getting a full repaint or some other frivolous work where you might hope to recoup some of the cost when selling...
If I applied this logic to maintaining my 328xi with 200k miles, I would have let it go to shit two years ago. So, OP sells the car but since he isn't 90 he says f*ck the Lexus and buys another 335. Then in x number of months or years he's on the hook for the same job, or will have do another job over again that he had already done on his previous car. I'm totally onboard with DIY'ing this if possible. Makes no sense to pay somebody to do this when you can do it for less than half. But if you're not able to, the car is in good shape otherwise, and you plan to keep it, why not?
10-15-2020, 01:02 PM | #11 | |
Rep 1,532
In my experience the hobbyists are just as knowledgeable and reliable as an average shop. |
10-15-2020, 01:04 PM | #12 | |
Rep 6,312
But I admit from a DIY perspective it goes down easier when you gotta do big fixes. Now if you don't care about having that many HP and the car then okay sell it and get something else. |
Vivek.1367.50 |
10-15-2020, 01:08 PM | #13 |
Rep 135
Have you ever had your spark plugs and coils replaced? It may be just that at this mileage. $250-300 DIY.
If you’re not interested in turning a wrench then best bet is sell it or trade it in. |
10-15-2020, 02:25 PM | #14 |
Rep 901
Proposed solution - replace the plugs, coils and injectors yourself, these are right on top of the engine and can be done even in autoparts store parking lot. And you can def buy parts cheaper. As for the valve cover, try to get more quotes. Ideally, better to get it done yourself for even more savings but it is more difficult than spark plugs and confidence levels for diy repairs do vary. So yeah, just get more quotes for the valve cover.
10-15-2020, 02:52 PM | #15 | |
Rep 259
i also agree that you can buy a whole new car for that price, I only paid $3700 for mine
2007 e92 335i 6 speed FBO
CPE Catted HiFlo DP's BMS SSK & JB4 |
10-15-2020, 07:53 PM | #17 |
Rep 147
10-15-2020, 09:14 PM | #18 |
Rep 2,025
Drives: 2008 E92 328xi
Not trying to be that guy but buddy of mine has been running for 6 months on fbo tuned with eBay refurbished injectors for a minuscule fraction of what the fcp euro ones are and the car is doing great. I think it's amazing someone would pay 4K to get new injectors and a valve cover gasket lol. That's 500 short of what I paid for my e92
10-22-2020, 12:11 PM | #19 |
Rep 124
Hmm, ok guys, thanks a ton for the advice!
On balance, I think I will probably end up parting with it. I got one dealer offer that said, given the repairs it needs, they would likely be willing to give me only ~$1,500 or so for it, which seems a bit crazy low (considering the wheels and tires on the thing should be worth 1k alone). |
10-22-2020, 12:37 PM | #20 |
Rep 135
Please please please do yourself a big favor by just buying and installing plugs and injectors for $1200 or so and install them within an hour or two. As for the VCG, you could also do yourself but if you aren't comfortable with tools then get a reputable indy to do that for $1000 at most. I don't want to tell you how to live at all, but I think you'll be happier in the end by just avoiding the stealership.
10-22-2020, 12:56 PM | #21 | |
Rep 4,203
10-22-2020, 01:39 PM | #22 | |
Rep 1,532
