Break pad sensor problem
10-15-2020, 03:03 PM | #1 |
Rep 141
So my break light is on because the car thinks my pads are worn. Car has all new break pad and rotors. I've tried resetting it but it just shows the clock then doesn't reset still shows "————" for miles. Sensor doesn't look worn but maybe I'm wrong any help would be great. Also if I can't get them to work I'm going to just cut them and put the wires together for now because I can't get sensors till next week.
10-15-2020, 04:06 PM | #4 |
Rep 141
Rear and No I never replaced them. I just thought it was weird the car said the pads were worn. Before I did the breaks it was fine then a week after I did the breaks I got the error. How do you tell it's a worn sensor so I know ?
10-15-2020, 08:29 PM | #7 | |
Rep 18,801
Second, the brake pad sensor is a plastic, consumable device that has a simple electrical wire circuit which breaks as the brake pad is consumed over time and wears down (thins) until the wire circuit in the sensor no longer passes electricity. Once the circuit breaks, a red "Brake" light illuminates on and stays illuminated until the brake pads are replaced along with a new sensor. If your brake pads are a week old, buy an new brake pad wear sensor and replace it. The system can then be reset.
10-15-2020, 08:30 PM | #8 |
Rep 141
Yeah obviously so I cut the sensor and connected the two wires. Did you not read the first post I said I won't be able to get a new sensor for a bit. And FYI the problem is fixed by bypassing the sensors.
10-15-2020, 09:41 PM | #9 |
Rep 7,215
You didn't fix the problem. You patched it over with a band aid. The problem is the sensor was broken and you needed to replace it with a new one. That's a perfectly fair question, but honestly, the way you write makes it difficult to help.
10-15-2020, 10:37 PM | #10 |
Rep 818
Just leave wire connected together.. What you are saying is you need to reset break service history.. I believe you can do it in BC hidden menu. We been running cars for 100+ years without these sensors so no worries ..
10-15-2020, 10:42 PM | #11 |
Rep 141
Finally someone who can read. Yeah I reset them and it's good now I appreciate your input.
10-15-2020, 10:44 PM | #12 |
Rep 141
Thanks for the English lessons but idk why you're so worried about spelling when anyone with common sense can understand the post.. thanks again for all the great information 😂😂
10-16-2020, 02:25 AM | #13 |
Rep 18,801
It's called the difference between doing things correctly versus doing them half-assed. Whether it is the proper use of nouns and verbs or repairing BMWs, Hass is the former and you obviously are the later.
10-16-2020, 02:43 AM | #14 | |
Rep 18,801
or... So of the 50 or so years disk breaks have been commonly found as standard equipment on automobiles, over 80 percent of that time, BMW has been utilizing the pad-where censor as a safety device. Last edited by Efthreeoh; 10-16-2020 at 08:24 AM.. |
10-16-2020, 06:25 AM | #15 |
Rep 3,921
Efthreeoh17427.50 StradaRedlands4998.50 |
10-16-2020, 09:44 AM | #17 |
Rep 818
If you got some 19's all you need is you eyeballs.. Well maybe some glasses for you old timers.. But hey if you dont want to inspector your car from time to time than a were pad sensor is for you.. I can see why BMW used these considering who there customer base is.. But for us commoners its not needed, we can do without.. So there is two different people in this, followers and leaders.
10-16-2020, 10:33 AM | #18 | |
Rep 7,215
"I don't need these new fan-dangled sensors!" (that aren't even new) - in the same breath - "you guys are old for relying on these new sensors". |
Efthreeoh17427.50 |
10-16-2020, 12:40 PM | #19 |
Rep 818
As I was corrected these sensors are not new... You say to do it right does this mean that 95% of the cars on the road are wrong for not having these sensors?
So they should install these sensors if they don't have them? You have these sensor on all your vehicles? If not does that mean that you yourself dont actually fix these issues? And yes ten dollars a piece is a lot of money for an party hat trick. I stand by my statement, if you actually work on your car, theses sensors are a waste of money. Last edited by Tunafish; 10-16-2020 at 12:45 PM.. |
maarzz1.50 |
10-16-2020, 12:51 PM | #20 |
Rep 7,215
yes, I do have these sensors on all of my vehicles (3 BMWs of varying vintage), and yes, they all work because they are inexpensive, easy to replace, and a good way to know when the brakes need serviced.
Replacing all of the pads and rotors is an order of magnitude more than $10, it's easy to just include that in the price - like replacing the rotor set screws so they don't get rusted in place next time I need to touch them. Plus I'm not paying labor, so it easily makes up for the cost. $10 is not a lot of money; if you think so, you probably shouldn't own a 10 year old 335i, it's going to cost you a lot more than that. |
10-16-2020, 01:11 PM | #22 | |
Rep 3,921
Also, 'their'. Their money. Last edited by Tambohamilton; 10-16-2020 at 01:22 PM.. |
