Serpentine belt
10-17-2020, 08:49 AM | #3 |
Rep 18,801
You can go on Gates website and get some good information on the subject. With modern serpentine belts, you have to look for micro cracks on the ribs. Gates says the wear rating is between 60,000 to 90,000 miles. On my N52's I've replaced the belt at 100,000 mile intervals. On my Z4 I actually let it go to 105,000. It was worn, but not catastrophically so. I was not having any drivability problems.
Now on my GM Truck, around 9 years and 75,000 miles the power steering began to act up. It was getting intermittently hard to turn the steering wheel; the truck has 33'' tires as factory equipment. Instead of panicking that the steering rack or pump was going bad, I replaced the serpentine belt, and that cured the problem. Obviously the belt was slipping. The belt looked perfectly fine and was not squealing. Going on my record of not replacing good parts preemptively, and knowing the industry manufacturers recommend an interval of near 100,000 miles, I follow a 100,000-mile replacement interval.
213e90n51367.50 uncoturner5.00 |
10-17-2020, 08:51 AM | #4 | |
Rep 780
Drives: 2009 BMW 328i, Honda Civic Hat
10-17-2020, 10:19 AM | #6 | |
Rep 171
JK But this is perfect advice Get the belt a bit earlier then needed Less mess and hassle to deal with |
10-17-2020, 11:10 AM | #7 |
Rep 13,122
The tensioner is usually the bigger problem or oil getting on the
belt . The Belts will last a long time these days. It the tensioner gets weak the belt can walk off the tensioner. |
10-17-2020, 01:54 PM | #8 |
Rep 2,529
Drives: 2011 328i Wagon
Given what can happen if the belt comes off on these cars (sucked into the engine and causing VERY BAD THINGS to happen), as a low mileage driver I replaced mine on a schedule rather than by miles. I did the tensioner, idler, and belt on my wagon at 8 years and 46K, and just did the new-to-me convertible at 50K. ~$100 every 8-10 years and ~50K is cheap insurance. Basically, I just did it as part of a major all fluids/filters service on each car. At 48K, the idler on the wagon was starting to chirp, and if I am taking the belt off, I'm not putting the old one back on.
But if I pounded on the miles like Efthreeoh I'd probably do 100K as well (but keeping a sharp eye and ear on the pulleys). IIRC that's three years for him...
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option '11 128i Convertible - Space Gray on Savannah Beige, 6spd manual, also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire |
Efthreeoh17427.50 |
10-17-2020, 02:12 PM | #9 | |
Rep 18,801
Looks like I'm due soon for belt #4. Gates info I was referencing earlier: https://www.gates.com/us/en/industri...belt-wear.html Specifically from Gates website, " Tech Tip #1: Belt Inspection Changes With traditional Chloroprene (neoprene) serpentine belts, standard diagnostics called for replacement of the belt if it showed three cracks in a three inch section. However, today’s EPDM belts are much more resistant to cracking, since they can run up to 100,000 miles or beyond without visual cracks - despite the belt being worn to near failure. This resilient material quality makes EPDM belts more durable than their chloroprene counterparts, but also significantly harder to conduct a visual belt wear diagnosis."
213e90n51367.50 |
10-17-2020, 03:49 PM | #10 |
Rep 6,968
Drives: 2007 Black/Black 335i e90
10-17-2020, 04:02 PM | #11 |
Rep 4,203
Drives: '11 335is | '16 Macan Turbo
Nothing lasts forever
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
213e90n51367.50 |
10-17-2020, 04:06 PM | #12 |
Rep 780
as long as i grow old with it and flying cars are above me. Ill be chillin with my e90 in my garage next to my dream cars. Black 997.2 S and a prelci Blue 325i e90. And Green 1990 Mitsubishi Montero
10-17-2020, 06:55 PM | #14 |
Rep 780
hehehe saw this one with original owner
10-18-2020, 12:27 AM | #15 | |
Rep 2,529
Shame they can't come up with something like wear bars on tires.
10-18-2020, 01:31 AM | #16 |
Robot
1694
Rep 2,193
Even cold November rain.
I'm on my second belt at 135K. Belt was first changed at unknown mileage by previous owner in 2011, but my tensioner was bending with the pulley out of plane with the other pulleys so I had to replace it. $16 for a brand new Continental belt made in Germany was a no brainier, but the old one looked just fine. The new Continental belt was identical to the old belt, with all the same markings except the BMW logo and part number. |
10-18-2020, 06:37 AM | #17 | |
Rep 18,801
10-18-2020, 11:51 AM | #18 |
Rep 2,529
My lust for that is strong! Always liked these and the early Isuzu Troopers. Of course, in Maine they dissolved into dust in short order.
