Help Choosing Coolant (in store now!!)
10-20-2020, 05:54 PM | #1 |
Rep 20
Hi guys
I was driving my new to me 335i (n55) when I got the low coolant light on my way home from work. I opened the tank and saw green coolant (I know that shouldn’t be right!) However I drove a few miles to the only store near me autozone. They have peak blue coolant (says works with Bmw) Or the other choice is universal green coolant. I do not want to drive further with low coolant, so would I be able to mix blue and green? Or should I just top off with green then flush it all out and put genuine Bmw coolant at my earliest convenience Thank you so much on this urgent matter |
10-20-2020, 06:01 PM | #2 |
Rep 1,532
Top off with distilled water, drain and refill with Genuine BMW at your earliest convenience. Not sure the current temperature in NJ but you really don't need to have that much coolant in your car (as long as the level is correct, it can be well over 50% distilled water depending on ambient temp)
10-20-2020, 06:04 PM | #3 |
Rep 4,203
Drives: '11 335is | '16 Macan Turbo
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
10-20-2020, 06:05 PM | #5 |
Rep 4,203
I wouldn't bother. I'd just do distilled water if it's not close to freezing there yet, then 50/50 with BMW
10-20-2020, 06:10 PM | #6 |
Rep 20
10-20-2020, 06:14 PM | #7 |
Rep 4,203
It's a low liquid level warning, not an overheating warning. Distilled water is better at thermal convection than coolant also. It's more to keep the water from freezing in the lines in cold temps.
Vivek.1367.50 |
10-20-2020, 07:30 PM | #10 |
Rep 946
Use distilled water and order bmw coolant. I’d recommend getting the real stuff from fcpeuro as they were cheaper than non bmw brand off amazon
07 E92 335i 6MT, MMP inlets, DCI, VRSF 7.5 competition intercooler, VRSF catless downpipes, VRSF chargepipe, 335is clutch, Vader Solutions stage 2 LPFP, MHD stage 2+, Hawk HPS 5.0 pads, R1 Concepts drilled slotted rotors, TSW Nurburgring 19x8 19x9.5
10-20-2020, 08:56 PM | #11 |
Rep 323
I used Preston coolant in all my cars including Lexus and BMW vehicles. Never has any issue. You can spend more money buying BMW coolant, but I don't think it performs any better. Preston is being used in million and million vehicles over these years and it's proven...
10-21-2020, 09:20 AM | #14 |
Rep 324
I've worked at BMW dealers from the 70's until 2007. I found some old BMW antifreeze in the garage in still sealed bottles. Probably from the 90's. It's green and the ingredients are exactly the same as the blue stuff. The only difference is the blue has bitters added. I assume to keep animals from drinking it. I put it in my E90 this year when replacing the water pump and tstat. We'll see how that goes. Couldn't make myself throw it out.
The Nightman1091.50 |
10-21-2020, 09:22 AM | #15 |
Rep 6,968
Drives: 2007 Black/Black 335i e90
I use Amsoil coolant with a coolant booster. Zero issues
10-21-2020, 09:25 AM | #16 |
Rep 946
I’ve been told mixing them can cause it to crystalize inside your cooling system and eventually cause failure and requirw replacement of everything. No personal experience but for $20 i’ll just buy bmw coolant and have the peace of mind
10-21-2020, 12:41 PM | #17 |
Rep 323
BMW water pump goes bad around 60K with BMW coolant anyway. So it's not the coolant, it is the water pump. My 1997 Camry with 300K miles still has the original water pump and I started using Preston since 45K miles.
10-21-2020, 02:52 PM | #18 | |
Robot
1694
Rep 2,193
Also, the BMW branded coolant isn't very expensive. In fact it's the cheapest coolant available around me without having to wait for shipping. $18 for concentrate which makes two gallons of 50/50 mixed coolant is cheap. I'm sure there are lots of suitable alternatives but when I can get the BMW branded stuff cheaper that's what I'm going to stick with. |
10-21-2020, 03:41 PM | #19 | |||
Rep 4,330
new BMW coolant is now green. The color doesn't mean anything The type and chemistry does. You can't go mixing things willy nilly. The original fill was a phosphate free HOAT coolant. Quote:
My wife's volvo needs a new mechanical pump at 120K because it's weeping. We owned a from new 1998 camry that needed one at 88K miles. I've done multiple Jeep 4.0 pumps in less mileage. I've done Jeep WJ v8 pumps at less mileage. I've done a chevy malibu pump at less mileage. I've done chrysler v6 minivan pumps at less mileage. care to try again? |
e90yyc2426.50 |
10-21-2020, 04:17 PM | #20 | |
Art Collector
2427
Rep 3,450
10-21-2020, 04:24 PM | #21 |
Rep 946
Mine lasted 90k but i wasnt referring to the waterpump specifically. When i said everything needs replaced i was told that means everything. Expansion tank, hoses, radiator, waterpump ect... a 97 camry is like comparing a basketball to an orange. Theyre both round and thats about where the similarities end
10-21-2020, 04:52 PM | #22 |
Art Collector
2427
Rep 3,450
Camborghini
