E90 seagul noise or tea kettle
10-21-2020, 04:42 PM | #1 |
Rep 217
So my girls n52 has this noise and its annoying af. The car idles good everything is good. It only has a engine light thats off n on when i was able to scan it. It was vacuum leak.. is this sound from the vacuum leak... btw this sound only happens when car stops. Never while driving.
Anyone experienced this before. |
10-21-2020, 05:12 PM | #2 |
Rep 2,099
I think the PCV is usually more like a whistle. But if you're throwing that code...
Also check your belt/pulleys. Could be the tensioner needs to be replaced (or one of your pulleys are dying). Little hard to tell since its listening over video. |
10-21-2020, 06:45 PM | #4 |
Rep 4,330
remove drive belt, start engine.
eleiminate belt driven accessory as possibility. then open the hood and use a stethoscope to identify the culprit. |
10-21-2020, 09:40 PM | #5 |
Rep 2,014
Valve cover
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3 Michelin PSS | M3 Control Arms LUX v4 LEDs | Shadowline Grills | Lip Spoiler |
10-23-2020, 01:12 PM | #6 |
Rep 675
I have the same noise. Mine goes away when I open the oil fill cap. So I thought it's the PCV valve and replaced it. The noise didn't go away.
Belt and pulleys replaced too. |
10-24-2020, 09:56 AM | #8 | |
Rep 4,330
the uro one has been fine in my junk for 30K miles and was less than $200 IIRC. in my experience trying to glue plastics together in a place exposed to oil and heat never really works well. |
11-10-2020, 02:54 PM | #9 | |
Rep 675
I also suspect my main seal gasket is blown and sucking air from there. I might be also talking nonsense. |
