Atf change and filter change for n52 at dealership price?
10-23-2020, 03:32 PM | #1 |
Rep 344
I just got a 50% off any service (excluding oil change and tires) from my local bmw dealer, up to 200 dollars . I have never taken my car there to be serviced, just buy parts and fluid. My question is how much is a regular atf change and filter change at a bmw dealership? Could be worth using the 50% off just so I don't have to get under the car and get dirty for once lol.
10-23-2020, 04:09 PM | #3 |
Rep 344
10-23-2020, 04:15 PM | #5 |
Member
30
Rep 115
Drives: Metallic Black 2006 325i
probably around 1500 to 2k at dealer. best go to a reputable indy shop.
unrulyteach392.00 |
10-23-2020, 04:24 PM | #6 |
Rep 344
Just called and they it is a service they perform, the deciding factor will be when the service advisor calls me back with the quote, (assuming the 50% off will make it comparable with a Indy shop regular quote but I could be wrong we'll see)
Buug95917932.50 |
10-23-2020, 04:25 PM | #7 |
Rep 344
10-23-2020, 05:18 PM | #8 |
Rep 98
Here in the UK I was quoted full flush with fluid, and filter pan change for £350 all in at a tranny specialist. Cheaper without the flush, maybe £250. This seemed comparable with other costs I read about. Dealer more expensive for sure but anything over £500 is surely taking the piss I did it myself and it was indeed doable and messy but parts cost about £150 so an extra £100 for a specialist to do it actually wasn't that bad in hindsight. I would think your idea to use the discount on this is a fairly good idea.
F22leo245.00 |
10-23-2020, 05:24 PM | #9 | |
Rep 946
Drives: e92 335i, f22 m235i, e30 325is
But guaranteed a BMW dealership will quote you at least 1k for the work. It's not hard to do yourself, you just need a vac pump |
10-23-2020, 05:42 PM | #10 | |
Art Collector
2427
Rep 3,450
As you probably know, it’s kind of a messy job with a very specific procedure that must be followed exactly. Would be great to have someone else do it for you.
F22leo245.00 |
10-24-2020, 10:52 AM | #11 | ||
Rep 344
10-24-2020, 01:16 PM | #12 |
Rep 1,682
I don't think it's worth it going to the dealer. Looks like the best price for the kit (filter, o-ring and pan gasket) is on RM European then. They also list the plastic pan for ZF under the same car, so make sure yours is really GM (take a peek).
Febi filter $12.28 24117593565 Meistersatz pan gasket 24117572618 $17.05 Beck Arnley has a kit #044-0368 that lists $36.89-$45.88 online (Summit Racing, Rockauto, Amazon). https://www.amazon.com/Beck-Arnley-0.../dp/B008YDDRFA https://www.beckarnley.com/find-my-p...~328i%20xDrive For fluid I use Valvoline Max Life ATF. It is around $20 a gallon at Wally World. Drain and refill takes just shy of 4 qts. I think with filter it is 5-6 qts can't remember for sure. Therefore parts, shipping and 2 gallons of Max Life you are looking at around $100. I have changed the mechatronic sleeve o-rings for our ZF 6HP (and the "double D" seal and 4 tubes). The sleeve o-rings turned mushy and were a different material than the black o-rings used on the GM sleeve. If you are dropping the pan, might as well do it. The access to the external connector is a little tight even on our FWD. Here are some DIYs. On AWDs I imagine you are going to have a transfer case and driveshaft blocking a few more things: https://www.e90post.com/forums/showthread.php?t=1257476 https://www.e90post.com/forums/showthread.php?t=573490 Last edited by mainbearing; 10-24-2020 at 01:24 PM.. |
F22leo245.00 |
10-25-2020, 02:06 PM | #13 | |
Rep 344
10-25-2020, 02:33 PM | #14 | |
Rep 323
$40 aftermarket parts $27 for 6 quarts of Valvoline Maxlife $32 for case of beer |
10-25-2020, 03:04 PM | #15 |
Rep 2,367
Drives: 2011 335i
I wouldn't even ven ask them about that they gone give u bs answer and even if they quote u it's gone be ridiculous, i got mine changed at an Indy for 1-2hr labor
10-25-2020, 03:16 PM | #16 | |
Rep 323
