Can't get O2 sensor ready for SMOG and tried everything
10-25-2020, 06:52 PM | #1 |
Rep 281
I have a '11 E92 335is. I put the engine back to stock, flashed the MHD stock map, and checked the option for stock downpipes. After 4 months of normal driving you would think my car would be smog ready but it's not. I've done tons of drive cycles and just got home from doing another one just now. I've been focusing on the O2 part of the cycle and I drove for 30 minutes at 58MPH with no AC and no radio on. And then I turned around and did it for 40 more minutes and still the O2 is not ready. Used the cruise control and the RPM's never went over 2K. All other sensors have been ready for months. What can I do? My registration is now expired but I payed the fees. I'm at my wits end with this drive cycle.
10-25-2020, 07:03 PM | #2 |
Rep 818
You checked the option for stock down pipes.. But do you stock down pipes? If not a tune not going let you pass.. It will only clear the error you see.. Error will still be there..
10-26-2020, 12:30 AM | #3 |
Rep 281
I had downpipes but I put the stock ones back on and then checked the box for stock DPs in MHD
10-26-2020, 11:55 AM | #5 |
Rep 281
Never heard of resetting adaptions before. I'll have to look into that. Is there a way to actually uninstall the MHD completely? Would it make a difference? I'm wondering if I should just take the car to the dealership to have it checked out.
blueberry335i0.00 |
10-26-2020, 12:34 PM | #6 |
Rep 818
You can reset adaption in MHD.. Where you check for error codes.. The cars always adapting but this might force the process.. You can remove MHD under stock, flash back to stock...
10-26-2020, 02:17 PM | #7 |
Rep 281
