11-01-2020, 03:06 PM | #1 |
Rep 37
I know that the f30s have a little shake on startup, I myself have experienced it, but recently my car has been shaking really bad on startup. It only gets worse when I put it in drive and let it roll. Feels like the whole car is going to fall apart.
It idles fine, just above 500 rpm after it's warmed up and I've checked the charge pipe and down pipe for leaks Car is a 2013 335i FBO stage with 110,000 miles The car has been running great on stage 1, but the day before the issue I really started to push it, doing multiple WOT and it felt great, but the next day I woke up, started it and now we're here. In my opinion I don't think it has anything to do with the axles, as when I rev it in park the shaking gets considerably worse. Any advise would be great. Thank you Also no codes |
11-01-2020, 06:13 PM | #2 | |
@_sunbish
284
Rep 611
11-01-2020, 06:34 PM | #3 |
Rep 835
Drives: Bmw 335i f30 N55 ( sold)
The only time I experienced terrible start ups was when I had a charge pipe burst, and when my intake inlet cracked after the Intake too the turbo. Also when I had a coil that broke inside the cylinder. Is it possible the tune is keeping the codes off?
2012 bmw 335i sedan
VRSF catless DP VRSF 5? HD IC Stock intake(had open before and was sick of noise) BMS CP 550i 351m rims with 275/245 set up. No tune as of yet. |
11-01-2020, 06:38 PM | #4 | ||
Rep 37
Car has 110,000 miles on it |
11-01-2020, 06:42 PM | #5 | |
Rep 37
Thank you |
Tpriest7893227.00 |
11-01-2020, 06:44 PM | #6 | ||
Rep 835
2012 bmw 335i sedan
11-01-2020, 07:22 PM | #7 |
Rep 2,376
Running cold start delete? Mine does the same - would far from call it violently though.
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
11-01-2020, 07:48 PM | #8 |
@_sunbish
284
Rep 611
These cars eat spark plugs pretty quick when tuned. I flashed my tune at 65k miles (on original plugs) and had to replace them at 75k because of a slight miss under load and a shaky idle. Same thing happened again at 95k. I'd highly recommend changing them every 15-20k miles, when tuned.
11-01-2020, 07:52 PM | #9 |
Rep 37
11-01-2020, 07:53 PM | #10 | |
Rep 37
Thank you |
11-01-2020, 08:03 PM | #11 |
@_sunbish
284
Rep 611
11-02-2020, 09:21 AM | #12 |
Rep 426
Have you had the valves walnut blasted? Just tossing out common maintenance items... lots of other good suggestions here.
Glacier Silver Metallic 335i X-Drive - Can't leave well enough alone... Fabspeed DP, Wagner Evo Comp II IC, ER CP, BM3 Stage 2 93 OTS, Bimmertech Amp (more to come... always more) Graphite Metallic X3 (nothing yet, but... you know) |
11-02-2020, 11:33 AM | #13 |
Rep 7,622
Check for shadow codes.
Some people also have luck running a couple bottles of techron complete fuel system cleaner through (one bottle per tank, a few tanks in a row). |
11-02-2020, 12:54 PM | #14 |
Rep 37
11-02-2020, 12:55 PM | #15 |
Rep 37
11-02-2020, 01:32 PM | #16 | |
Rep 7,622
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 MHD app can scan for shadow codes. I assume BM3 can also. It will basically show both shadow codes and active codes. You could have some misfire or other shadow codes even if they aren't active. |
11-02-2020, 02:50 PM | #17 |
Rep 57
Something similar happened to me a few months back before going stage 1, but I got a drive train malfunction along with a misfire code.
It idled decently, but would shake horribly and back fire once in motion. My issue ended up being a stuck open fuel injector. Maybe something similar? I'd try flashing to stock, and seeing if you get any unusual pop and bangs without any burbles from the tune. |
11-02-2020, 02:53 PM | #18 | |
Rep 37
Thanks |
11-02-2020, 07:04 PM | #19 |
Rep 37
Update:
Drove the car around more and got a code. Looks like its going to be the pre cat o2 sensor. Gonna replace it, not sure if it'll fix it, but it's worth a try. Also my oil sensor is broken. Doubt that's causing the idle, but I'm just gonna replace everything. Thanks to everyone who helped 👍 |
11-02-2020, 08:29 PM | #20 |
Rep 2,376
Car is running open-loop during warm up so I'd be surprised if it is the O2 (fingers crossed)... I logged a cold start just the other day as mine is also a little rough. I have asked my tuner to raise idle rpm to 1000 during warm up cycle.
My idle normalizes in the green area.. Cold start https://datazap.me/u/harkes/fabian-v...21&zoom=43-330
(A Dane in China) Last edited by harkes; 11-02-2020 at 08:45 PM.. |
11-02-2020, 09:15 PM | #21 | |
Rep 37
Thanks |
11-02-2020, 11:15 PM | #22 | |
Rep 7,622
Although looking at cold start will be a little different than WOT pull interpretation. |
