F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > F36 Brake upgrade to M Sport
proTUNING Freaks
      11-08-2020, 06:11 PM   #1
Ari-msport
Ari-msport's Avatar
United Kingdom
13
Drives: BMW 420d Gran Coupe
Hi all
Have been searching on here and elsewhere regarding upgrading my standard brake kit to the m sport set.
I own a f36 420d gran coupe m sport.
All is m sport from factory apart from the brakes for some reason
Unfortunately when the initial owner was going through the m sport package, seems they opted out for the m sport brake kit
Being a small engine size I guess my existing set are the more basic standard set.
I've sourced a complete used (nearly new) set of m sport calipers, pads, discs. Have also purchased new reinforced brake hoses.
From my research it's all should have bolt on. Fronts went on ok. Rears seem to be an issue
My existing rear discs have the handbrake size of 185mm. The M sport discs that are 345mm diameter can only accept a 160mm handbrake shoe. Much smaller that what is already fitted.
Is the answer to just purchase a new 160mm hand brake shoe and spring fitting set ? Will the new 160mm handbrake shoe bolt straight onto what there abs then the m sport disc fit over that all with no issues ?
Also, behind the handbrake shoe is some sort of mounting disc. Is this required to be replaced also ? See image.
Any help will be appreciated, especially if you've experienced this or know exactly what I'm trying to explain.
Also, I've had conflicting info regarding if these brake upgrade requires coding or not. Most mechs have said no. Even 2 local BMW dealers have said it's not required. But the consensus on the forum is it does.
Any input on this also.
      11-08-2020, 09:29 PM   #2
smrtypants44
smrtypants44's Avatar
Drives: 2017 440i
I think you can buy aftermarket 345mm discs with the smaller size for the handbrake shoe.
check out 8th post in this thread
https://f30.bimmerpost.com/forums/sh....php?t=1666002
      11-09-2020, 12:15 AM   #3
Ari-msport
Ari-msport's Avatar
United Kingdom
13
https://f30.bimmerpost.com/forums/showthread.php?t=1666002
I've seen this page.
Just can't find anything like that in the uk
Tried my local shops gsf and euro car parts
      11-09-2020, 01:54 AM   #4
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
Are you you can't find a 345mm rotors with 185mm e brake?
      11-09-2020, 02:39 AM   #5
Ari-msport
Ari-msport's Avatar
United Kingdom
13
I've looked online but can't see anything suitable that I can order
Discs will probably cost £150 and up
I can buy a new handbrake shoes and spring holder kit for about £40. I was wondering if other parts would have to be replaced also?
If not I can just change the handbrake shoes
f30post
