11-09-2020, 03:13 PM | #1 |
Rep 29
Build help
I have a 2012 335I new to me low mileage, and I’m wondering on opinions on what mods I should do. I don’t plan on running a fuel mixture and I know that will hinder performance but my goal is 400WHP so I far I’ve only done CTS turbo CP I play on buying CTS IC and high flow DP as they offer a military discount.
Any advice will be appreciated |
11-09-2020, 03:25 PM | #2 |
Rep 7,622
Step 1 is to come to terms with the fact that you wont reach 400whp with stock PWG turbo, and decide if you are willing to invest the time/money to go turbo upgrade. If rather you want to set aside your number goal and enjoy the car without a turbo upgrade, your best bet is basically do IC+CP+DP as you said you are and run a OTS pump gas map for those mods. You'll probably be around 350whp depending on fuel quality, etc. Keep it simple and reliable.
And clarify, does not running a fuel mixture mean you wont run WMI either? |
11-09-2020, 03:30 PM | #3 | |
Rep 29
11-09-2020, 03:35 PM | #4 | |
Rep 7,622
Yes, WMI = water meth injection. From what i have seen, Canada can have pretty bad fuel quality, although that may not apply in your area. Also, just because you run a PS2 doesn't mean you need to max it out... you can easily run less power and just not work the turbo as hard. Of course, you can also get a lower 'stage' turbo if you want to keep it as small as possible, but then you will just have to work it harder. For 400whp you will basically need EWG-size turbo (operating pertty hard), and depending on fuel quality, WMI. Then the typical IC+CP+DP, and i would do an inlet (MSTv2 my recommendation) if you are doing turbo for sure. |
11-09-2020, 03:50 PM | #5 | |
Rep 29
11-09-2020, 06:20 PM | #6 | |
Rep 7,622
11-09-2020, 08:30 PM | #7 | |
Rep 29
11-09-2020, 08:53 PM | #8 | |
Rep 7,622
11-09-2020, 10:54 PM | #9 | |
Rep 4,174
My recommendation: MST/Pure Turbo inlet (this will allow your turbo to work more efficiently) Turbosmart diverter valve (the stock version is pretty weak, and BMW saw fit to use an higher capacity version on the M2) Dorch Stage 1 or 2 - depending on if you’re upgrading the turbo, stage 2 would provide more headroom. Downpipe - AA/Fabspeed if you need to pass emissions, otherwise any catted is as good as another VRSF Race/Wagner Evo 3/VRSF competition- from best to least. the biggest ICs out there would keep your AITs and more consistent power. The VRSF stuff is cheap and it works XHP software - I drive a manual so I don’t really care - but guys swear by it. Edit - Recommendations are for EWG, I'm sorry. Last edited by AmuroRay; 11-10-2020 at 11:20 AM.. |
11-09-2020, 11:08 PM | #10 |
Rep 4,174
Again, this setup is good for over 400whp* peak on a stock turbo, and more than 380whp* at 6500rpm.
You also want to consider what you want to do with the car. You’ll still need these same mod even if you decide to go PS2 or larger. *numbers not fully verified. |
11-10-2020, 12:07 AM | #11 | |
Rep 7,622
11-10-2020, 09:38 AM | #12 |
Rep 29
The VRSF comp IC is reasonably priced but is the hpfp Necessary if I’m only going to run 91 as it’s all I’ll be able to get when I’m back on base?
11-10-2020, 11:11 AM | #13 | |
Rep 7,622
You can read my post here: https://f30.bimmerpost.com/forums/sh...1769353&page=2 |
AmuroRay2315.00 |
11-10-2020, 11:19 AM | #14 |
Rep 4,174
Ahh, I missed that.
Mods: Yes.
11-10-2020, 12:50 PM | #15 | |
Rep 29
11-10-2020, 01:27 PM | #16 | |
Rep 7,622
After you install your IC+CP+DP and go to stage 2 OTS map, you can decide what you want to do next. You can either install the PS2 and run a 91 map and see how it feels, or you can install the WMI on stock turbo and try running a higher octane map to get some more power out of the stock turbo. Since the PS2 install doesnt really overlap with WMI install, you can really do either one first. |
