11-13-2020, 06:58 PM | #1 |
Rep 779
KW V1 coilovers for Xdrive, installed on a RWD
There is a set of these for sale local to me. They are KW part number 102 20 00S. They are meant to be installed on 335ix, 340i, and 435ix. The seller claims he had these installed on his 435i rwd without issue.
Can this be done? Or is he trying to be a slick (scumbag) salesman? I searched, but didn't find anything definitive to my situation. Thanks |
11-13-2020, 08:25 PM | #2 | |
Rep 1,934
In the other end Rwd coilovers on xdrive will hit the front axle boots.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
LA1Z24363.50 |
11-14-2020, 02:04 PM | #3 |
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
You can install them, but you'll need to get a different passenger's side end link unless you have EDC. I'd check to make sure the xdrive spring rates work for your lighter front end.
11-14-2020, 03:46 PM | #4 |
Rep 1,288
Drives: 2015 335i xdrive Msport Mbrake
very good point... would be stiff as heck... I suggest he gets the proper coilovers... I absolutely love mine (Flatout Suspension)...
