11-27-2020, 01:07 PM | #1 |
Rep 55
Been patiently looking into finally starting to tune my 435i, nothing too crazy just more power and sound.
The plan is: AA Catless DP JB4 Injen intake FMIC (eventually) Main question I have is; is there any precautions I should take to make sure it's ok to send it. I know you can't just slap bolt-ons on and call it a go, but this seems fairly simple for what I'd like to achieve. Really any advice/suggestions would be helpful |
11-27-2020, 01:24 PM | #2 |
Rep 461
Your going to need an upgraded charge pipe. The stock one is plastic and prone to crack even with stock boost levels.
You will also want to up the priority of the fmic. With the addition of boost, iats will quickly overwhelm the stock intercooler. Intercooler is more of a necessity than the intake, which would really be just for sound. |
11-27-2020, 02:50 PM | #3 | |
Rep 1,237
2023 M2. ZB. Manual.
2024 m235i |
juliomadara721.00 |
11-27-2020, 03:52 PM | #4 | |
Rep 55
11-27-2020, 03:58 PM | #5 | ||
Rep 1,237
Someone please correct me if I'm wrong. I've only been driving a bimmer, and really into cars since March.
2024 m235i |
juliomadara721.00 F32Huncho13.50 |
11-27-2020, 06:45 PM | #6 |
1297
Rep 3,536
that cp is a must, and do the intercooler asap too
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
Silverlining_m21743.50 |
11-27-2020, 08:33 PM | #7 |
F36 GC
143
Rep 259
The hierarchy of parts installed in my opinion would be
1. Charge pipe 2. FMIC 3. Downpipe 4. Tune 5. Intake if you must purchase one. I would get inlet over intake Charge pipe for reliability and peace of mind. The FMIC will keep intake temperatures in check and allow the engine to continue to produce peak power after driving for awhile. Majorly beneficial on stock engine and will feel a small but noticeable HP increase from the FMIC. Downpipe frees up the turbo to exit more air faster. Again majorly beneficial on stock car as well as a really nice hp increase from the downpipe. Once these mods are installed then I feel is the perfect time to introduce the tune. Your car will be best equipped and will be better capable to handle the extra stress. I've toyed with a couple intakes and compared them through data logs with lackluster results. Stock or Mppk + drop in filter still seems to be as good or better than any other intake performance wise. Sound wise there are plenty that make more whooshy noises. Happy building!! Chase |
11-27-2020, 10:28 PM | #8 | |
Rep 327
2019 X3 M40i Alpine White/Black Vernasca stock
2015 435i Alpine White/Black Dakota FTP chargepipe, Dinan intercooler, M Performance exhaust, Carbahn Stage 2 tune |
11-28-2020, 09:18 AM | #9 | |
BimmerPost Supporting Vendor
24350
Rep 191,156
depending on how old your spark plugs are, you might experience a misfire due to the high boost. If that happens, upgrade to the NGK colder plugs and you are set.
11-28-2020, 11:39 AM | #10 | |
Rep 40
11-28-2020, 03:24 PM | #11 |
BMW CCA Member
490
Rep 808
My 2-cents...
1. Charge pipe 2. FMIC 3. Limited Slip Differential 4. Tune I know there's a BIG debate online when people talk about the LSD ONLY if you *turn* the car... but it's stupidly amazing how much more power you feel... even pointed straight. Plus leaving trails of 11's is fine too. |
juliomadara721.00 Pussiwillow522.00 |
11-29-2020, 02:53 AM | #12 | ||
Rep 55
I understand when modding you cut 30%-50% of the engine life and maintenance intervals will be need to be doubled but from a general standpoint have you heard anything in a little worried after just hitting 100K on the odometer. Big fans of XPH and reading your comments too! |
11-29-2020, 02:55 AM | #13 | |
Rep 55
Recommendations for FMIC and tune? I'd like to go JB4 but I eat good feedback for BM3 or MHD |
11-29-2020, 02:57 AM | #14 | ||
Rep 55
11-29-2020, 08:28 AM | #15 |
Rep 29
I'd say charge pipe and FMIC first to run stage 1 (I have BM3). I know most people say that to run stage one you don't need any mods and although this is true, I recommend changing at least the charge pipe. Not an expert by any means, just speaking from experience. My BM3 was delivered before any of my other parts (charge pipe, DP, FMIC, intake) and I ran stage 1 for a week before my charge pipe exploded.
The guys at XPH are great and will give you a good price and will guide you through the process. |
juliomadara721.00 mike@x-ph.com24349.50 |
11-29-2020, 09:39 AM | #16 | |
Rep 55
11-29-2020, 09:53 AM | #17 |
Rep 29
I used the forum to read about it. I was in between JB4 and BM3, IMO BM3 is easier to instal since it is not a piggy back but just a flash. It literally took me 20 mins to figure out how to flash and do it. Happy with the performance, the burbles and the open exhaust valve. JB4 may be a good option if you'd like to wire stuff and if you have more experience. I am a beginner in terms of mods so that's why I chose BM3. There are so many threads in the forum, spend some time to look at them before you decide for yourself.
Good luck and keep us posted! |
juliomadara721.00 |
11-29-2020, 11:05 AM | #18 | |
F36 GC
143
Rep 259
I have Evolution Racewerks Competition IC. It is quite large and I purchased it with the long term plan of upgrading the turbo (still might at some point). I love it and it keeps my IAT really solid in my logs. I also have ER Charge Pipe and ER Turbo to Intercooler pipe so I liked having all 3 from same manufacturer. Bm3 is the 2nd type of tune that I have ran and I have nothing but positive feedback on it. Ease of use, powerful tunes, and good customer service from them. I have never used JB4 so I cannot comment on that but I do know a little about it from reading posts on here. I would personally steer more towards either BM3 or MHD, both nice platforms. |
11-29-2020, 12:33 PM | #19 | |
24350
Rep 191,156
I dont necessarily agree that mods cut the engine life. Im buying 2014 335 this weekend with 110k miles and it will be fully modded . I do not expect any maintenance issues outside of what a stock 335 with 110k miles will have If you use trusted mods and run the recommended maps for your mods and fuel, you will not damage your engine in any way. The transmission will hold as well without any issues.
Pussiwillow522.00 juliomadara721.00 |
11-29-2020, 03:01 PM | #20 | ||
Rep 55
I agree the ZF8 can hold the power but for how long? I've read a lot that the max torque output is already set in the stock trans (350nm-550nm). Others speak differently but there's been no concrete evidence (that's I've seen) that it can take on more of the load. Just curious if you seen/heard anything since you're a trusted source. Either way I will tune the car regardless but scary to think about since I would like to have the car for 4-5 more years. |
11-30-2020, 08:34 AM | #21 | |
24350
Rep 191,156
I find Stage 2 FBO with stock turbo safe for high mileage cars
https://x-ph.com/sale/ Phone number 702-494-9435 Last edited by mike@x-ph.com; 11-30-2020 at 08:40 AM.. |
11-30-2020, 12:39 PM | #22 | |
Rep 7,622
CP+IC --> Stage 1 Add DP --> stage 2 (or 2+ if MHD) There's no reason for a JB4 with what you are seeking. Get BM3 or MHD. Read both threads if you want to understand the nuanced differences between each, otherwise just pick one. When you are complacent with those mods, add a turbo inlet (MST v2 highly recommended). I demonstrated this is a tangible improvement both with data and subjectively. Alternatively to the inlet, another mod to satisfy the itch and pair with other "FBO" mods is XHP. Eventually, do both, as drivability and throttle response will be excellent. As you alluded to, there are torque limits in the 8AT. XHP is the way to 'properly' up those limits so you can get full power in 3rd and 6th gear. Skip the intake unless you want noise. Same for exhaust. Of course, before any mods, do maintenance as mentioned. Trans pan and fluid should have been done around 75k miles. Plugs every 30kish once tuned. Go OEM plugs (bosch) with stock gap. NGKs are not an "upgrade" - only switch to those if you have issues with OEM. Read numerous threads in the maint. section of these forums if you want more recommendations on service intervals. Inlet thread (find my post with data later on): https://f30.bimmerpost.com/forums/sh....php?t=1656337 My intake review thread: https://f30.bimmerpost.com/forums/sh....php?t=1765289 My datalogging thread, for after you tune: https://f30.bimmerpost.com/forums/sh....php?t=1732327 |
