11-28-2020, 04:24 PM | #1 |
Rep 176
F30 N55 Multiple Codes on Cold Start, Limp Mode
So I got the following codes all of a sudden in a morning startup. I would randomly get the first one but after warming up and restarting the engine, it would dissappear. Car is FBO upgrade turbos with catless dp, but the cat codes were disabled by my tuner.
120408 - Charging pressure control: Switch-off as consequential reaction. 123002 - Wastegate valve activation: Short circuit to ground 12B102 - Oxygen sensor heating before catalytic converter, activation: Short circuit to ground. 12B302 - Oxygen sensor heating after catalytic converter, activation: Short circuit to ground. 1B5202 - Supply, terminal 15N_1: Short circuit to ground. |
11-30-2020, 12:22 PM | #3 |
Rep 7,622
Car year, miles, more specific mod list?
Have you checked all the wires over by the O2s and WG? You have 4 short circuit to ground codes and they appear to all be over in that area. Did you install the DP yourself? |
12-01-2020, 09:31 PM | #4 |
Rep 176
131k miles, SpeedTech stage 3 efr 8374 turbo kit, FBO. I had the shittiest shop install it, and another shop reinstall it. I'll check the wiring in that area, all the codes showed up at the same time on a freezing cold morning, could that have anything to do?
12-01-2020, 09:55 PM | #5 | |
Rep 7,622
The freezing cold could have been a coincidence... hard to say. If you subsequently warmed the car up and restarted and the same codes came back after clearing i would say the temperature was not a direct cause. |
12-02-2020, 08:15 PM | #6 | |
Rep 176
But the second shop as been pretty good and will have them look into it, it's most likely some wires as you mentioned as the turbo fitment is pretty tight. Anyways, I ordered the dorch stage 2 hpfp this black friday, so hopefully it'll arrive before I take it to the shop so they can install it at the same time 🤤 |
12-02-2020, 08:19 PM | #7 |
@lbb_kev
496
Rep 516
Have you talked to Jeff at Speedtech? He's incredibly helpful. Might put you in the right direction.
Speedtech Stage 3 (8474) | Remus Exhaust | Wagner EVO 3 | XClutch | DS2 + Lift Kit | Nostrum S2 Injectors | TI E5LM | Torqbyte EKP | Intrax 1K2 | SPL | Drexler GT Race Light LSD by limitedslip.de | Schirmer Diff Lift Kit
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage |
12-04-2020, 09:05 PM | #8 |
Rep 176
