12-04-2020, 03:24 PM | #1 |
Rep 72
How do you monitor your cars
I know most of u guys are using mhd or bm3 to log your cars but is there any other software to monitor onboard our cars. I am not using either of this softwares and i want to monitor boost, timing,afr, knocks and other stuff onboard. Please share info.
12-04-2020, 03:32 PM | #2 |
Rep 1,237
Bimmerlink
2023 M2. ZB. Manual.
2024 m235i |
12-04-2020, 03:45 PM | #3 |
Rep 7,622
You can also use "generic" OBD2 apps. I use torque pro for my 3000gt, for example, and it should be compatible provided you have the correct OBD2 device/cables, etc.
Note however that some PIDs (i.e., parameters you want to measure) may be custom within BM3/MHD so you may not be able to directly monitor things like knock, timing corrections, etc. |
12-04-2020, 04:44 PM | #4 |
Rep 92
The Bimmerlink app is a great option! Very simple interface and lots of sensors you can monitor. I use the Veepeak OBDCheck BLE+ dongle.
2024 BMW X3M Comp ~ Individual Gentian Blue
12-04-2020, 05:52 PM | #5 |
Rep 1,433
You might be interested in P3 Gauges: http://www.p3cars.com/bmw/
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
12-07-2020, 03:06 PM | #6 |
Rep 72
Is it possible to monitor afr,lambda and timing with bimmerlink because i saw that there is a payed license for it and i want to be sure this is my software before i pay it.
12-07-2020, 04:10 PM | #7 | |
Rep 7,622
FYI, you can buy the MHD monitoring module separate from other modules. IIRC its $99. You of course will not have flashing or OTS maps, but you can monitoring in real time, datalog, etc. Just an option if you want a more common/tried and true datalogging platform. Using this also ensures you get all the custom PIDs available in MHD, such as timing corrections. |
12-07-2020, 04:56 PM | #8 |
Rep 142
I use obd fusion with a veepeak obd plug in if I just want to see my temps and such. I use bootmod3 for actual logs. Only reason I don't use bootmod3 all the time is I don't feel like keeping my phone plugged in(actually I'm just broke and don't have the WiFi agent)
2017 M240i
CD919 Custom E40/flex fuel tune | catless downpipe | TU Pump | XHP Stage 3 | MHD flexfuel kit |
12-07-2020, 10:20 PM | #9 | |
Rep 92
https://www.bimmerlink.app |
12-08-2020, 07:48 PM | #10 |
Rep 183
damn... didn't know that we can datalog with bimmerlink... I've purchased mhd monitor license like for 3 times the price of bimmerlink
does someone has feedback on bimmerlink VS mhd datalog feature? edit: I've found nothing on youtube |
12-09-2020, 12:52 PM | #11 |
Rep 72
I’ve ordered the obd dongle 2 days ago and I am waiting delivery now. When i recive it i will post feedback immediately
12-22-2020, 04:15 PM | #13 |
Rep 72
Well pretty much it looks good but I don’t see option to monitor AFR can someone tell me how the hell this program doesn’t have this option ?!?! I’ve paid 35 euros for license and they don’t have one of the most important thing for monitoring ?
12-22-2020, 04:41 PM | #14 |
Rep 7,622
Did you look under lambda? And not just "AFR"?
12-25-2020, 04:43 PM | #15 |
Rep 72
Spoke with the support and they gave me a link to download the latest beta version which works perfectly and has 10 times more sensors to monitor. And also i have my lambda value 😃 I am very satisfied and now i can monitor properly my car.
e38740imd65.00 |
12-26-2020, 05:28 PM | #17 |
Rep 33
Are you looking specifically for monitoring or logging ? You can run MHD or Bimmerlink to monitor and log. Bimmercode is to change things like the seat belt warnings and such, it won't log anything. You can alternatively use an OBD plug in like a ScanGauge II to show specific values like trans temp and such.
https://www.scangauge.com/products/scangauge-ii/
2013 335xi F30 - Mineral White Metallic
12-27-2020, 08:10 AM | #18 |
Rep 354
Been using Bimmerlink for some time and while its a great app for live monitoring of sensor data, the time intervals at which it records during data logging causes the data log to be unusable. I've yet to see an option to change it.
Also, i've seen phantom 'Knock' recorded on several occasions. For everything else it can do, still a great app. New battery registration, exhaust flap control, fault code reading/clearing etc. |
12-27-2020, 08:43 AM | #19 | ||
Rep 183
Good to know, now I have less regrets about my purchase, thanks! |
12-18-2022, 02:55 PM | #20 |
Rep 35
Drives: F30 n55, e70 diesel
Bump, MHD gauges via wifi adapter
12-30-2022, 08:22 PM | #21 |
Rep 10,373
I don't. I keep my vehicles stock because I'm not interested in chasing down problems caused by tunes and FBO.
There's a reason why the majority of problem cars have tunes or FBO.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
01-01-2023, 09:28 PM | #22 |
1297
Rep 3,536
Omg 😆 🤣
