12-06-2020, 05:30 PM | #1 |
Rep 35
M2 OEM + PE Hybrid Exhaust
Here's my idea to modify the OEM M2 Exhaust to M2 MPE. The goal is to keep the exhaust nice and quiet but also have the ability to loud. The yellow circles are the OEM exhaust valve.
M2 Hybrid exhaust, HOW IT WORKS?: when it's in comfort/eco modem, the valves remained closed, exhaust soundwaves and gases go through the muffler. When it's switched to Sport / Sport+ mode, the valves open up, exhaust soundwaves and gases go through the muffler and outer tips, a straight piped design just like the MPE. Do you think this is a good design to accomplish the goal that's mentioned above? Are the valves located at the right location (Closer to the Y pipe? Closer to the tips?) |
12-06-2020, 05:46 PM | #2 |
Rep 7,622
Have you seen this thread?
https://f30.bimmerpost.com/forums/sh...d.php?t=819125 I know the M2 OEM exhaust is different, but modifying the muffler internally might be easier than what you are showing. How are you going to get an extra valve and how are you going to integrate it into the new pipes you are proposing to add? The fab might be fairly complicated. You could also just consider adding a electric cutout that you control manually. |
12-06-2020, 06:14 PM | #3 | |
Rep 35
12-06-2020, 06:40 PM | #4 | |
Rep 7,622
Also, are you sure your MPE sketch is correct? It doesnt really make sense because the muffler would basically be bypassed all the time. To acheive what you are looking for, i think you need to do what i showed in my revised sketch. You just add a new valve that serves as a bypass for the muffler. The original value remains in place. Meaning when valve is closed, there is zero change from what you have right now. But when valve is open, you will have your current valve open function (open other side of muffler) + you will add the muffler bypass. |
12-06-2020, 07:18 PM | #5 | |
Rep 35
12-06-2020, 07:21 PM | #6 |
Rep 35
Yes, there will not be any valves on the inner pipes, it will just be like and sound like sport+ because that's when the valve is opened on the oem exhaust. But even when the valves are opened, it's pretty quiet, just perfect for daily driving.
12-06-2020, 10:52 PM | #7 | ||
Rep 1,934
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
