12-07-2020, 09:04 PM | #1 |
Rep 379
I have the borla atak now and I used to have CG precision R1 (still in my garage).
If I cut this piece (https://www.ecstuning.com/b-cg-preci...ps/0001r1~cgp/) and cut off my Borla muffler and weld it on, will it be louder than my full borla exhaust? Or will it be louder if I just get a catless dp? |
12-07-2020, 09:56 PM | #2 |
Rep 7,622
I'm confused by your question...
Yes a muffler delete will be louder than borla muffler. Yes a catless DP will be louder than any catted DP, oem or aftermarket. |
12-07-2020, 10:42 PM | #3 | |
Rep 379
Now I should have got my CG precision R1 repaired instead of buying the ATAK. I would get it repaired but then I just wasted 2k cad on the atak. |
12-07-2020, 11:59 PM | #4 | |
Rep 7,622
? DP + ? midpipe + ? axleback comapred to ? DP + ? midpipe + ? axleback Are you asking about OEM DP with borla midpipe and muffler delete vs CG precision + borla midpipe and axleback? |
12-08-2020, 08:08 AM | #5 |
Rep 3,680
I too am slightly confused, but the answer to the question I've quoted is: assuming the same downpipe, yes.
Instagram: rjd_f30 | Current: EBII 2013 335i 6MT RWD & Sprint Blue 2008 Audi RS4 | Retired: 2013 328i, 2000 XTerra, 2022 Civic Si |
12-08-2020, 11:44 AM | #6 | |
1297
Rep 3,536
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
12-08-2020, 08:22 PM | #7 | ||
Rep 379
12-08-2020, 09:55 PM | #9 |
Rep 7,622
From everything i have seen, the borla atak muffler provides little "muffling", whereas the OEM DP vs catless provides quite a bit. So i think catless DP + full borla exhaust is going to be louder than OEM DP + borla midpipe + muffler delete. The best way to get an idea is just look for videos of OEM DP + muffler delete (with or without OEM resonator) and compare to catless DP with borla exhaust. You should be able to find those. They are both going to be quite loud.
12-09-2020, 10:50 PM | #10 | |
Rep 379
12-10-2020, 12:32 AM | #11 | |
Rep 7,622
Were you the one who kept asking about catless DP in the other thread? I have several examples to illustrate that catless DP is louder all the time than any catted DP (cold start, idle, part throttle, WOT, etc), and significantly louder than OEM. You are literally removing something that muffles sound. |
12-10-2020, 05:42 AM | #12 | ||
1297
Rep 3,536
its more quiet than stock. troll you had to know I was going to do this right?
Pussiwillow522.00 |
12-10-2020, 08:19 AM | #13 |
Rep 1,597
