12-09-2020, 01:07 PM | #1 |
Rep 323
What is this screeching sound? 2012 335i F30
There is a screeching sound when driving slow like first or second gear. After the doors auto lock can hear it several times. What is it?
12-09-2020, 03:11 PM | #2 |
Rep 57
That sounds like the exhaust valve opening and closing. Someone can correct me, but I think at 0 - 2.5k rpm its closed, anything above, will open. Also depends on the drive mode / conditions your in that will change when it's open / closed. Mine is audible, but not that loud.
12-09-2020, 05:57 PM | #3 |
Rep 2,658
Exhaust flap would be my guess.
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Sutphin Custom Tune - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI - Dinan Midpipe
12-09-2020, 05:59 PM | #4 |
Rep 323
The sound occurs in any drive mode (Sports, Comfort, etc). It occurs whether the engine is hot or cold. The sound sort of seems to be coming from the wheels because sometimes the sound is muffled when in a far away wheel and other times its noisier.
The wheel speed sensor or ABS sensor don't normally make such a noise, do they? |
12-09-2020, 07:09 PM | #5 | |
Rep 7,622
Min/max speed? Which corner/part of the car its coming from? Have someone sit in different parts of the car and/or listen from outside driving by. Only when turning? More when turning one way or the other? Are you on stock wheels/tires/suspension? I would give everything a good look over. |
12-13-2020, 11:05 AM | #6 | |
Rep 323
Sound is coming from all over not just one spot. I think its different wheels. Yes, everything stock and in good shape. It sounds more like an electrical solenoid noise and not scraping noise to me. |
