12-11-2020, 10:26 PM | #1 |
Rep 12
The dreaded knock
Is this the knock, we don't want to hear?
https://www.youtube.com/watch?v=fVLL...ature=youtu.be |
12-12-2020, 11:57 AM | #5 |
Rep 7,622
Listen under the car and see if it is louder.
Get a mechanic's stethescope and move around to confirm its from the bottom end. Check oil pressure. Pull the oil filter and inspect it for fine metal. |
12-12-2020, 12:47 PM | #6 |
Rep 1,288
Drives: 2015 335i xdrive Msport Mbrake
@ Cal96 ..... My opinion is don't run the motor anymore than needed... do what jeremy said about the oil filter/ drain the oil check for metal... but if that's the case hopefully you just have to drop the oil pan and replace the bearings...
what was typical oil change mileage on car? when you put new oil in it and it gets quieter that's also a sign... . Last edited by FastF30; 12-12-2020 at 01:12 PM.. |
12-12-2020, 01:51 PM | #7 |
Rep 820
Drives: 2021 BMW X3 M
@OP do you know what caused this?
2014 BMW 335i M-Sport - SOLD
2020 BMW M340i - SOLD 2021 BMW X3M |
12-12-2020, 04:43 PM | #9 |
Rep 5,386
Hard to tell if this is rod knock without the engine being slowly revved up and down to around 3k rpms. Revving up and down like this will induce the knock, usually on the rev up.
If the rod is spun, the damage is already done and metal all throughout the motor. |
Pussiwillow522.00 |
12-12-2020, 10:43 PM | #10 |
Rep 12
won't know the history cause I bought it off my buddy knowing it had a knock. just done an oil change (from that video clip) also checked the filter and looks good. I guess he changed it before he sold it to me. I posted cause I wanted a confirmation. I will be listing to it underneath like Jeremy said. What else can make that sound? can you check oil pressure without a guage? My plan was to tackle the rod bearings myself but still 50/50 , lol 120k miles
12-12-2020, 10:53 PM | #11 | |
Rep 1,148
12-13-2020, 12:38 AM | #12 |
Rep 2,376
A spun rod... F me that would be a sight to behold
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
12-13-2020, 12:03 PM | #13 | |
Rep 7,622
12-13-2020, 12:36 PM | #14 |
Rep 1,288
do these oil pans have a magnet in them? .. I googled and saw magnetic drain plug but think that was aftermarket... check all other possibilities and then pull the pan... start looking for a used motor as an option...
12-13-2020, 01:26 PM | #15 |
Rep 10,301
Cal96, what is year is your F30 and how many miles does it have?
Small percentage of N55 engines in 2013 model year have been affected by premature connecting rod bearing wear. It is a known issue and BMW replaced the engine if diagnosed at the dealer within the warranty period. The diagnostic is performed on the engine oil to identify excessive metal shavings. |
12-14-2020, 11:48 AM | #16 | |
Rep 5,386
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
12-14-2020, 04:05 PM | #17 | |
Rep 1,121
Drives: 2015 BMW 435i Xdrive MSport
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
12-15-2020, 01:11 AM | #18 |
Rep 1,288
Never mind...
