12-31-2020, 12:26 PM | #1 |
Rep 395
Removing exhaust tips
Looking for a way to remove the round exhaust tips on my G20 330e and swap them with the 340i versions, had this in mind:
https://smile.amazon.co.uk/TGFOF-Dif...438683&sr=8-54 However I had a quick look underneath and can't see a way to remove the grey exhaust cover (tip). Mine also looks round but the 340i style seems to be more oval so not sure it would ever fit anyway. Anyone did this to theirs? Possible? If not I'll just swap them with round ones I guess |
01-02-2021, 02:40 AM | #2 |
Rep 99
Pretty easy to remove . On top side the exhaust tip has a snick ( not sure about the term) with 2 metal blades to fix it on a pin located on the exhaust tube. With a small screw driver for instance you should push laterally the metal blades to release the tip from the pin and them just pull it , should come with minimal effort .
Hope it helps |
01-02-2021, 05:17 AM | #3 |
Rep 395
Thanks and yeah I had a closer look and I can see it.
Thought they were just pushed on with clips on the inside. Any idea what the inlet/outlet diameters are? Not near the car for a few days so I can't check. |
01-02-2021, 10:47 AM | #4 |
Petrolhead
1943
Rep 3,521
To remove the stock tips, all you need to do is pull real hard. Wear thick workmen's gloves, sit on the floor, push your foot against the rear tyre and pull the tips with all your might. It'll slide right off. It's a little hard because of the pins on top but it's possible (that's how I did it).
Current:
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige |
01-03-2021, 06:59 AM | #5 | |
Rep 1,039
VipinLJ1943.00 |
01-04-2021, 06:16 PM | #6 |
Petrolhead
1943
Rep 3,521
I agree. My driver's side was wedged in there real tight too. Had to pull with all my might and then wiggle it a bit. I thought I was going to pull the whole exhaust system out!
Current:
OM3RTA391.00 |
01-05-2021, 05:49 PM | #8 |
Petrolhead
1943
Rep 3,521
Like I always say. If I can do it, anybody can. I'm glad the tips on the 330i are so easy to remove. It's harder in other cars, requiring either a car lift or a very flexible body, neither of which I have
Current:
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige Last edited by VipinLJ; 01-06-2021 at 05:23 PM.. Reason: Fixed typo - many say to easy |
OM3RTA391.00 |
03-28-2021, 12:38 PM | #10 |
Rep 10
Thought of doing the same with my G21. Do you know if the original 340 diffuser will fit my car? I have a trailer hook on my car. Possibly only the original diffuser will fit?
04-14-2022, 08:15 PM | #11 |
Rep 161
I used some WD-40 to grease up space between the exhaust and the overlapping tips. Pulled and wiggled hard, but nothing that required near full force tugging. I replaced the stock tips with Shadowline tips, and those went back on very easy.
