02-02-2021, 10:30 AM | #1 |
BimmerPost Supporting Vendor
24358
Rep 191,163
*NEW PRODUCT* MAD Intercooler & Charge Pipe W/ Install Video
In this video, the stock intercooler and FTP charge pipe were replaced by the MAD FMIC 5" & CP
Upgrade from your stock intercooler to the MAD stepped core intercooler for maximum performance and reliability! The stock BMW intercooler is small, inefficient, and cannot keep up with the high boost that your tuned car targets. MAD BMW 5” intercooler will keep the intake air temperature in check, allowing your BMW to perform at its best at all times. The MAD F chassis BMW 5” intercooler uses a high fin density core for maximum cooling. It also features a stepped core design to maximize the cooling area. Weighing 22lbs only with dimensions of 21"x8.5"x5", It provides the perfect cooling solution for stage 1 applications. This intercooler is compatible with stock and aftermarket charge pipes. Features:
Fitment:
SKU: MAD-010 Upgrade from the stock BMW N55 charge pipe to the MAD N55 charge pipe for maximum airflow and reliability! The stock BMW N55 charge pipe is plastic and prone to failure. It's only a matter of time before the charge pipe to break. The MAD N55 charge pipe is a strong aluminum piece; it will provide better airflow and won't fail, and fits like stock. The MAD charge pipe retains the BMW C-clip and O-ring for the best fitment. Do not forget to move them from the stock charge pipe to the MAD option. The MAD charge pipe comes with two meth bungs; both bungs are sealed. If you do not intend to use methanol injection, keep them closed. Features:
Fitment: Fits Rear-wheel drive vehicles only.
SKU: MAD-017
02-08-2021, 10:17 AM | #2 |
24358
Rep 191,163
02-15-2021, 10:33 AM | #3 |
24358
Rep 191,163
MAD N55 charge pipe vs FTP
(nothing was wrong with FTP, we replaced it with MAD because we wanted to confirm fitment on the car that's all)
