What does "cat-back" mean and tuner question
03-03-2021, 08:15 AM | #1 |
Rep 12
Hello, i have a 2011 328i e92 n51, and I'm looking at exhaust modifications. I want to do afe catted headers so i can pass emissions, but am curious what "cat'back" exhaust setup is. Is this all the way back from the catted headers? Is this going back from a second cat further in the exhaust? Do i need all cats to not get an engine light? How far deep into the exhaust can i go removing cats until i get an engine light? Sorry for the billion questions, this is an issue I've struggled with understanding for awhile.
Also, who's a good tuner for the N51 that i can be confident will take my 3 stage intake with disa valves into account and all my other mods? Maybe if they can tune e85 too? Currently i have an off the shelf tune from turner and am not confident my 3 stage was tuned. I would like a custom tune. Any ideas? |
03-03-2021, 08:41 AM | #2 |
Rep 1,364
Drives: 09 E90 335i M-Sport 6MT RWD
Cat-back means after the cats; on these cars it would be considered behind the secondary cats (primarys are considered part of the headers/exhaust manifold).
Removing secondaries will have no codes and not affect anything unless you have a visual inspection; removing the primaries will show a code unless you do something about it. I know bimmerlabs has mentionned doing N51 tunes(they also do performance ones) but I believe its just "off the shelf" ones unless someone can correct me on that. |
03-03-2021, 08:52 AM | #3 |
Rep 2,738
Yotaismygame130.50 desertman1232215.50 Dan Bilzerian354.50 E92William1999.00 Navy Doc186.50 arciga181732.50 dephrank323.00 |
03-05-2021, 03:07 PM | #4 |
Rep 29
After you get headers, you could look into Stage FP for a tune.
DO NOT try to go for E85, it's only good on cars that have a turbo. It won't hurt anything but you'll make less power and waste money. If you're not going fully catless, I honestly recommend saving some money and following the steps on bimmerlabs to get a basic tune. Good luck! |
03-05-2021, 05:21 PM | #5 |
Rep 12
Is that actually true about E85? It's a 900$ kit plug and play and claims 10-15% gains at the wheels. Also, what are you referencing with the basic bimmerlabs tune? I have an intake and tune already, and I'm looking for more legal power ie catted headers, open exhaust behind it, and i was hoping the E85 claims were true. I'd like other opinions but im certainly glad i asked. I was looking on ecstuning and they had a flex fuel sensor that was plug and play.
03-05-2021, 07:59 PM | #6 | |
Rep 224
Drives: E92 328i 6MT
Bimmerlabs is great but I have had an awful experience with their custom tune. I have been waiting 5 months for a custom tune and haven't gotten anything after paying. 10-15% is a bit optimistic, I would say closer to 5%
2007 E92 328i 6MT | KW V3 | 3SI | SSR Type-C 18x9.5/10.5 | AA Headers
03-06-2021, 08:18 AM | #7 |
Rep 12
This quotea is what the device says it does. It says it should be compatible with my tune i already have. My brother is insisting it will not communicate with the motor and i will not see gains unless specifically tuned for e85, is this true? Is the engine still going to basically make no adjustments to the motor unless tuned? This sales page makes it seems like you plug it in and it should make engine adjustments automatically. Here is the link and info on page
https://www.ecstuning.com/b--advanced-fuel-dynamics-parts/proflex-commander-adaptive-e85-flex-fuel-system/pfc-e90328-k~dk/?pdk=AQ Product Details True plug and play flex-fuel for your BMW in about an hour with no tuning required. ProFlex Commander Features: Complete system - everything you need to run E85 100% Dyno tested for safety, durability and power gains Easy DIY installation - Under an hour with common tools Patented BlendSense technology adjusts in real-time with a 30-millisecond refresh rate True flex-fuel - switch from gas to ethanol and back anytime Improved injector management for more power on gas or E85 7-10% More wheel HP and torque on E85 (dyno proven) No tuning required - Compatible with stock or performance gas tunes; instantly adapts to new tunes Cleaner emissions and cooler cylinder, oil and coolant temps Race grade fuel at the pump - high octane, low cost Compatible with power adders and bolt-ons ProFlex Connect app provides accurate, real-time ethanol content on your iPhone or Android device via Bluetooth Cold Start Plus - improves fuel atomization for easier starting in cold weather |
