03-05-2021, 02:51 PM | #1 |
Rep 37
Recently picked up the turner carbon intake for the n55 , was a pretty easy install but fitting the intake tube was a pretty hard task . (It sounds amazing and my car is stock) . The car does feel alittle delayed when pressing the pedal after the install can it be a air leak?
03-05-2021, 03:55 PM | #2 |
Rep 7,622
Air leak is unlikely, but double check your connections.
The more likely explanation IMO is the location and design of the MAF housing. Not only does it look like a different size/shape than sock but the location looks a little strage? I would be surprised if MAF readings were not affected. Common design flaw in most intakes. Datalogging is the main way to confirm. If you have the software and are able, you can try resetting adaptations and putting some miles on the car to see if it gets better over time. Stock intake is designed the way it is for a reason. |
03-05-2021, 04:31 PM | #3 | ||
Rep 37
03-05-2021, 08:55 PM | #5 |
Rep 1,934
The delay is likely from moving to an open filter. Much harder to create intake pressure now.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
03-05-2021, 10:15 PM | #6 |
Rep 2,658
Stock intake on the N55 is the best option. No open air intake is going to perform better than it, period.
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Sutphin Custom Tune - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI - Dinan Midpipe
03-06-2021, 06:06 AM | #7 | |
1297
Rep 3,536
hes running a ps2 ewg setup and his maf numbers are always super low. mid high 30s and.never breaks 40s. it's crazy. looks awesome though.
