03-06-2021, 02:22 PM | #1 |
Rep 15
BM3 Stage 2+ Data Log help
Just did a data log on BM3. Had some rough start ups after tuning, added ngk plugs, made it a bit better but not perfect. Worried about my timing being slightly off. Do I need new plugs and coils? Inserted is a picture of the log. Don't know how to add csvs without google drive. Further, my car is spitting flames on Stage 2+ with max aggressiveness burble. Can this damage my turbo? Thanks
https://drive.google.com/file/d/1IrK...ew?usp=sharing - CSV https://drive.google.com/file/d/1QRP...ew?usp=sharing - Screenshot |
03-06-2021, 05:53 PM | #2 |
Rep 774
too high setting on burbled would likley damage your catalytic converter way before your turbo. as for timing, usually fuel related, what tune amd what gas are you using?
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
03-07-2021, 01:46 PM | #3 | |
Rep 7,622
You can also read my thread on datalogging here: https://f30.bimmerpost.com/forums/sh....php?t=1732327 As to the burbles, the potential for excessive wear and tear on any component increases as you increase the aggressiveness. Excessive burbles are dumb IMO, but your preference may be different. |
03-07-2021, 09:17 PM | #4 |
Rep 15
My bad, pretty new to this
https://www.bootmod3.net/log?id=6039...729b5a22ccf734 Yeah I think turning the burble down is necessary |
03-07-2021, 09:19 PM | #5 |
Rep 15
03-08-2021, 07:08 AM | #6 | |
1297
Rep 3,536
pretty sure you're using the stage 2 93 tune...
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
03-08-2021, 07:22 AM | #7 | |
Rep 1,237
Also if it starts rough and smooths out, yes I believe it could be plugs, coils, or even an injector. The timing in your log isn't the worst I've ever seen, but it could be better, by using better gas than the tune calls for.
2023 M2. ZB. Manual.
2024 m235i |
03-08-2021, 11:13 AM | #8 |
Rep 15
Yeah my bad, stage 2 93 octane AGG. I changed the plugs to ngk gapped to .022 and the start up got better. Ill kick it down to 91 octane and see if it goes away. If not, I will try coils next and pray it isnt injectors
03-08-2021, 11:24 AM | #9 |
Rep 7,622
Are you running an intake? MAF readings look low, but then again this is 3rd gear and you didnt rev all the way out.
The log looks generally OK, timing corrections as mentioned above but good boost control it seems. I would also suggest going down to 91 octane map, turning off or down burbles, driving a bit, and relogging. Do 4th gear if you are 8AT, 2500-6500 |
03-08-2021, 01:48 PM | #10 |
Rep 15
I'm on stock box with K&N. What role does MAF play in performance? I'm sorry im relatively new to this. Proud of no boost leaks though! I installed everything myself, first time turning a wrench on my car haha. When I get time this week I will log 4th gear multiple times. I also had DSC on during this run
03-08-2021, 02:13 PM | #11 | |
Rep 7,622
MAF is the mass airflow sensor. The DME uses it to measure how much air is coming into the engine so it knows how much fuel to inject. Then fuel trims are used to correct fueling based on O2 sensors using closed loop feedback. Recommend reading my datalogging thread i linked above. |
