03-17-2021, 12:34 AM | #1 |
Rep 32
JB4 On the fly controls?
Hey, I was looking into perhaps getting a jb4, do the G20 models have on the fly map switching like the f30 does in the gauge cluster yet?
03-17-2021, 02:34 PM | #3 |
Petrolhead
1943
Rep 3,521
I've tried it once using the app (can't use the live cockpit like you could the gauges in the F30). I actually did it by mistake but it seemed to change maps on the fly. But I don't feel comfortable doing that. I always put the car in diagnostic mode to change maps, even if you don't need to.
Current:
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige |
03-29-2021, 10:55 AM | #4 | |
Rep 425
I had a very bad scare this weekend with my JB4, it was causing my car not to start. Luckily I was able to fix it though.
2020 MG 330i xDrive M Sport
2023 AR M3 Competition M xDrive |
03-29-2021, 01:00 PM | #5 | |
Petrolhead
1943
Rep 3,521
What happened with your JB4?
Current:
03-29-2021, 01:16 PM | #6 | |
Rep 425
Had a random CEL. I tried reading the codes multiple times and the JB4 kept stating that there were no codes but the CEL was still here. This was all while I was driving at the same time. I hadn't updated the firmware and there were 3 versions that had been released since I installed it, so I decided to update the firmware WHILE I was driving. Once I stopped, the JB4 stopped connecting to the app and then car started to bog down and I could feel a huge loss of power. Had to drive it in eco mode until I parked. Once I parked, I tried reconnecting the app again and it would not connect at all. So I popped the hood and checked all the connections and it still would not connect. So I turned off wifi and bluetooth on my phone and then re-enabled it. Once I did that it finally reconnected to the JB4. Once it connected, re-updated the firmware, read the code, cleared it, then CEL went away and everything went back to normal haha. I was definitely freaking out though because I was out of state from where I live.
VipinLJ1943.00 |
03-29-2021, 05:17 PM | #7 | |
Petrolhead
1943
Rep 3,521
But yes. I believe they say you should update firmware only when car is in diagnostic mode? I only do it at home (since, if anything happens, car would be stuck at home and not somewhere else). I've never tried updating while the engine was running. With my luck, whatever that can go wrong will go wrong if I tried that.
Current:
03-29-2021, 07:17 PM | #8 | |
Rep 425
03-29-2021, 08:14 PM | #9 | |
Petrolhead
1943
Rep 3,521
Current:
03-29-2021, 08:29 PM | #10 |
Rep 425
Not sure if its beta but I'm running v19. Nah, don't use E85 and don't plan to. Once I get CP and DP installed, I want to hit up Terry about doing a custom map 6. I'm just treating map 1 as low boost and map 3 as high boost for now. I'm usually on map 3 tho.
03-29-2021, 09:11 PM | #11 |
Petrolhead
1943
Rep 3,521
Yeah. I use map 2 as a back up map when I don't get any e85 and have to drive to a gas station where E85 is available. I used to be on map 2 or 3 before. I add E85 mainly for timing.
Current:
03-30-2021, 07:58 AM | #12 | |
Rep 425
Was it a noticeable difference going map 2/3 to a dialed in map 6?
03-30-2021, 10:15 AM | #13 | |
Petrolhead
1943
Rep 3,521
And yes. There is a noticeable difference. It isn't a huge difference per se. But my map 6 feels smoother than map 3. Also feels powerful. Dragy shows that there's a big difference in performance (almost 0.4s difference in quarter mile times). The 62-124MPH times are also around 1.5s faster with the new map 6. The main thing for me is driveability. It feels nice. Almost like a flash tune.
Current:
03-30-2021, 10:40 AM | #14 | |
Rep 425
03-30-2021, 11:00 AM | #15 | |
Petrolhead
1943
Rep 3,521
Current:
03-30-2021, 04:36 PM | #16 |
Rep 425
You've convinced me lol. Probably won't be doing the CP/DP until next month or so as I have a queue of parts just sitting in my crib that I need to install already but will definitely keep you posted.
VipinLJ1943.00 |
03-30-2021, 08:06 PM | #17 |
Petrolhead
1943
Rep 3,521
Let's see if I change my mind and get a DP after reading your observations! I've heard only good things and wonder if it's worth it on a lease. But hey. If it helps, I just might get one.
Current:
03-31-2021, 08:43 AM | #18 |
Rep 425
I think DP on a lease is fine. It's a fairly easy install so removing it before turning the car in shouldn't be too bad. Will let you know once I have it installed and get a map 6 tune!
03-31-2021, 09:58 AM | #19 |
Petrolhead
1943
Rep 3,521
It'll be fine as long as it's reversible. What I'm worried about is my competency regarding being able to install it. I mean. I broke a damn clip trying to install a JB+. Imagine what can happen if I try installing a DP
Current:
03-31-2021, 11:00 AM | #20 |
Rep 425
