03-22-2021, 07:41 PM | #1 |
Rep 32
Defective Jb+?
Hey all, I just got my Jb+ today. Plugged it in and the car wasn’t making any boost. I made sure to lock the car and let the ecu go to sleep, waited 10 minutes. Turned the car off and boom: CEL. I scanned it and there was a code for a short on the boost sensor. I disconnected it and let the car go to sleep, everything back to normal. Is there any chance that the Jb+ unit could be defective?
Addition: I tried reconnecting it again going through the steps and it doesn’t work I guess it’s defective and I’ll be contacting support unless anyone has any advice as to what the issue could be. Last edited by blackg20_330i; 03-22-2021 at 08:31 PM.. |
03-22-2021, 10:52 PM | #2 |
Petrolhead
1943
Rep 3,521
You drove the car and there was no boost? Were the connectors plugged in tight?
If you tried twice and had the same issue both times, could be a faulty unit. Not sure though. I had a no boost issue but that was because the connection was loose and came undone. Lol. Plugged it back in and all was well.
Current:
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige |
03-22-2021, 11:48 PM | #3 |
Rep 32
No, I made sure to plug it in, it clicked, then pushed in the white plastic lock on both the jb+ and the Sensor on the charge pipe. I’m gonna maybe give a shot at changing the position of the dial and reconnecting it to see if it’ll change anything. I know it’s a long shot but it’s worth a try at least. Hopefully BMS can help resolve the issue and won’t just make bigger issues for me this is already a headache and I have a code stored for the sensor and code 121201. Hopefully I can use the scanner at my shop to clear that so the dealership doesn’t give me a hard time if they see that. Real bummer to have this thing not work...
03-23-2021, 12:39 AM | #4 | |
Petrolhead
1943
Rep 3,521
And yes. Clear the code. That shouldn't be a problem. I've had millions of codes (from when my car got bricked when trying to flash with BM3 and from JB4 due to fuel issues and unplugged connectors). I cleared all those codes. When I took my car in for service (after all that happened), they said the car had no error codes and looked clean. Ofcourse I always remove piggybacks completely and drive the car for a few hundred miles in stock form to clear any codes that could linger (doesn't always have to work but I've been lucky so far *touchwood*)
Current:
03-23-2021, 06:48 AM | #5 | |
Rep 32
03-23-2021, 02:50 PM | #6 | |
Rep 47
03-23-2021, 02:53 PM | #7 | |
Rep 47
03-23-2021, 07:00 PM | #8 |
Petrolhead
1943
Rep 3,521
Interesting! Sounds like they got a bad batch of JB+s? I had one and it made boost fine. Car was faster than stock. Wasn't long before I moved on to the JB+ though
Current:
03-24-2021, 11:38 AM | #9 |
Rep 47
Maybe bad batch, not sure... But I wasnt down for any engine problems lol not going back... If I ever go to a tune, it would be back to a bootmod3 maybeeee, for now i love my MST air intake
03-24-2021, 01:46 PM | #10 |
Petrolhead
1943
Rep 3,521
Oh yes. Tunes are the best by far. If only BMW hadn't locked the DME.....
Current:
03-24-2021, 02:20 PM | #11 | |
Rep 262
Although I do worry about the likelihood that BMW would push through another DME update that would nullify the tune at some point in the future. Any clue how often this happens? |
VipinLJ1943.00 |
03-25-2021, 11:14 AM | #12 | |
Rep 47
Just be aware that if you do a tune with bootmod3 and you do an over the air update for a Idrive that the tune will be deleted and may cause a bench tune |
03-25-2021, 12:25 PM | #13 | ||
Rep 262
03-30-2021, 08:49 PM | #14 |
Rep 32
So they sent a replacement out. The replacement was defective as well so I’m going to be asking for a full refund and going with either dinan or turbo transformer... how could you send one item that is defective and then the replacement also be defective...
03-30-2021, 09:18 PM | #15 |
Petrolhead
1943
Rep 3,521
Ahh. So looks like they did get a defective bunch then? I've heard good things about TT. Let us know how it goes
Current:
03-31-2021, 11:20 AM | #16 | |
Rep 47
04-02-2021, 03:41 PM | #17 |
Rep 949
FYI there was a batch of around 50 JB+ systems that had the wrong firmware loaded. You know you got one of those from the bad batch if you install it and get a CEL right away. If you have one just email them and they will send a replacement and a return label for the faulty one.
The normal support guy doing the email didn't know so a few guys got sent out 2 of the bad ones until they realized what the problem was. |
VipinLJ1943.00 |
04-17-2021, 06:24 PM | #18 | ||
Rep 7
04-17-2021, 06:49 PM | #19 | |||
Rep 262
04-19-2021, 05:48 PM | #20 |
Rep 47
04-19-2021, 05:49 PM | #21 | |
Rep 47
04-21-2021, 09:29 AM | #22 |
Joint Chiefs of Staff
24208
Rep 190,807
it must be a bad batch
