03-28-2021, 10:34 AM | #1 |
Rep 60
Do you miss the M1 / M2 console buttons?
I used to have an E92 and now I currently have an F80 that I love. One of the newer reasons I love my current car, aside from how the nose and hood look, is the presence of my console buttons. For the uninitiated, the console buttons are the physical buttons on previous M cars near the gear lever that allow you to customize traction/MDM, throttle/power, steering weight and suspension stiffness/EDC.
IMO, I actually have three M drive modes — M1, M2, and realtime-customized based on which console button I press for other specific driving conditions. The benefit of this is, I can be in my sportiest M2 setting and then on the fly change the suspension stiffness to a little softer if a new road I'm on is crappier than other roads or be in my more comfortable M1 setting and then bump up any one of the other settings based on what I feel like. When I found out that in the new 2021+ M cars, the typical console buttons had been replaced with a single M mode button, which is actually a shortcut to an iDrive menu, I immediately reconsidered getting a new one. For all the previous-generation M owners, do you miss the physical console buttons? This leads me to believe that now M owners only have M1 and M2 and cannot make real time adjustments to a particular driving condition. Is that true? I see that as a real design mistake. This isn't a mud-slinging post. I would like to get a new M, but I want to know what people think, so please don't get defensive. |
03-28-2021, 12:14 PM | #3 |
Rep 2,863
Yes, I agree that I miss the buttons by the shifter from my experience from the F85 X5M to the current F95 X5M, as the G80/G82 has the same set up. However, the M1 and M2 buttons are in a better position. At least I'll be used to it when the G83 finally starts production in a few months.
2022 G83 PCD & 2024 G05 S68 PCD
Retired:2021 F95 ZCP PCD,2018 F85 PCD,2018 F83 ZCP- ED/PCD, 2015 X5 50i PCD, 2015 435 vert ED, 2011 X3 PCD, 2011 335is vert ED/PCD, 2007 X3is PCD, 2007 335i vert PCD, 2004 328i vert PCD |
unfoundnemo1921.50 |
03-28-2021, 01:54 PM | #4 |
Rep 20,742
Drives: 2021 911 turbo
My understanding is that you can still make individual setting adjustments on the fly. There’s an extra step needed where you first need to access the iDrive menu with the console button but then, from there, you can toggle the different settings “on the fly” using the touchscreen.
IMO, the default setup on the G8X is also better than the one in the F8X with everything in Comfort. The fact that the F8X defaulted to the useless Efficient/Sport/Sport/D1 combo is my biggest gripe with the car, having to waste one of the M buttons for the granny/DD mode. With the G8X you have the default full granny mode plus two real M settings.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
03-28-2021, 02:02 PM | #5 |
Rep 8,083
Drives: 2024 X5 M60i
The setup button on the console brings up the settings menu and allows on the fly changes to suspension, brakes, traction, engine, steering, etc. Changes are made in real time. This was shown on one of the videos BMW M put out walking through the various parts of the new M models.
https://youtube.com/playlist?list=PL...5Is94c-8eDGCVv
Instagram: @Phxrisingphotography
Current - 2024 G05 X5 ///M60i in Java Green Past - 2005 E53 X5 3.0i in Titanium Silver; 2008 E92 335i in Montego Blue; 2019 G01 X3 M40i in Glacier Silver; 2022 G80 M3 Competition in Twilight Purple |
03-28-2021, 03:54 PM | #6 |
Rep 87
i don't miss the buttons, and find it pretty easy to change on the fly. Also easy to then make that change permanent. Plus, as noted, I think that the default setting is better configured - easy for my wife to just get in and drive without using any M buttons. So I can have 2 M buttons set for most situations I will need rather than having to waste one.
rajahfl38.50 |
03-28-2021, 06:11 PM | #7 |
Rep 474
yep car starts in default (unless you change it before firing up the engine) in Comfort/Efficient everything
To change on the fly just gotta press "setup" and then can use touchscreen or idrive knob. If you still want the physical buttons, the current X3M/X4M still provides that, but likely going away in the LCI next year.
G82 M4C - SPY, YMB extended, 826M Black, Carbon Buckets, Carbon Inlay, Prem Pack, Driver Assist
chicagofan0019257.00 |
03-29-2021, 04:04 AM | #8 | |
Rep 60
03-29-2021, 04:06 AM | #9 |
Rep 60
Not the steering wheel buttons; the M1 and M2 buttons are still there on newer M's albeit in better places. I'm talking about the console buttons near the shifter that control throttle, steering, suspension, and traction.
03-29-2021, 04:08 AM | #10 | |
Rep 60
03-29-2021, 04:22 AM | #11 | |
Rep 25,131
The reason there's a single button now is likely to the ever growing amount of customisation such as brakes now coming into the equation.
My car made front page of Bimmerpost
03-29-2021, 06:53 AM | #12 |
Rep 300
Drives: E92 M3 Comp/G80 M3 Comp on Ord
I still have my E92 M3 and I find the G80 way more convenient when you consider everything everyone else mentioned and hand gestures. Palms Down, open, close fist, open and M settings are right there. No need to take your hands off the wheel or look away from like of sight.
03-29-2021, 06:58 AM | #13 |
Rep 300
Isn’t hitting a simple red button near the steering wheel more convenient for the situation you described? I’m just trying to figure out how the placement of something so minor will determine if you buy this car. If manual wasn’t an option or the driving reviews were terrible then I can see you making the change but M Mode Buttons?
03-29-2021, 07:38 AM | #14 |
Rep 192
You can program the M button on the wheel to be all sport +, the only thing one might have to use the console for is to switch to a different M Mode (road sport track).
03-29-2021, 12:24 PM | #15 | ||
Rep 8,083
rajahfl38.50 |
03-29-2021, 01:59 PM | #16 | ||
Rep 60
JustChris17545.50 |
03-29-2021, 02:37 PM | #17 | |||
Rep 60
CanAutM321125.00 |
03-29-2021, 02:40 PM | #18 | |
Rep 4,709
rajahfl38.50 |
03-29-2021, 02:42 PM | #19 | |
Rep 60
I'm waiting for the AWD G80 anyways, so I have time to ask these questions. |
03-29-2021, 11:16 PM | #20 |
Rep 474
hope this helps .. this is my understanding from 3 days of ownership (and lots of idling just figuring out the menus and buttons ).. but really the reason they've gone from all the hard buttons to one "setup" button is because there are simply too many adjustable parameters now: engine, suspension, transmission, steering, brakes, dsc, 10-stage traction, start stop, exhaust, and upcoming awd
- TLDR if you are looking to change only one thing on-the-fly then yes the current setup will be more cumbersome, but really it's just an extra press ("Setup" on console or have the setup widget on your homescreen) - there are essentially 3 shortcuts: car always starts in softest everything, then two programmable red M buttons on the wheel which are very accessible - Some might have missed this: if you are in M1 or M2, press the button again takes you back to whatever you were in. So if you set something up custom then went into M2, press M2 again it takes you back to that setting - DSC, drivelogic, exhaust, and auto start stop hard buttons still remain - the "M Mode" button is a bit of a waste in prime real estate IMO, could've easily layered into instrument cluster menus like what AMG and Audi do, as it's purely a graphics aesthetic and lvl of driver assist setting and independent of actual driving settings
03-30-2021, 02:52 AM | #21 | |
Rep 60
03-30-2021, 10:18 AM | #22 | |
Rep 300
I was generally curious as to why the positioning of the buttons mattered to you. It was something that never crossed my mind. |
