04-03-2021, 12:21 PM | #1 |
Rep 21
M Performance exhaust flaps
Hi,
Has anyone ever experienced an issue with the m performance exhaust flaps where the flaps are stuck. See attached pictures for examples. I recently installed my MPE on my 18 M2 as well as installing my Cg-Precision-VSC-2 with modified wiring. The modified wiring is required for N55 engines. I do not believe the issue has to do with the CG-VSC, however when turning the car on with the device on, as the instructions state from CG, the flaps will not open nor close. The exhaust flaps appear to be stuck in their current positions as shown below. The connections from the CG wiring are as tight as they can be to the OEM Wiring and actuators themselves. Note: The CG settings are as follows: default-CLOSED ACTIVE-OPEN Does anybody know how to fix this issue? Also, is the M performance exhaust supposed to come with actuator clips for the drivers and passengers side? The original exhaust comes with one actuator clip as shown below. Any advice helps. Thanks Last edited by ///MPIRE; 04-03-2021 at 12:47 PM.. |
04-04-2021, 12:16 AM | #2 |
Moderator
29661
Rep 13,138
Also try this. Maybe it helps.
Ensure that:
For the "MPE Hack": see here.
///M is art ↔ Artemis
04-05-2021, 10:26 AM | #3 | |
Rep 21
04-06-2021, 09:18 PM | #4 |
Rep 291
Drives: 2023 BMW M2
1. Mpe doesn't have the clips!
2. Make sure the valves arent shorted out from your custom wiring by using the stock wiring into the left side valve. Hope this helps |
///M TOWN20296.00 |
04-07-2021, 08:03 AM | #5 |
Rep 21
So to confirm the MPE is also supposed to come with Actuator clips as well? One for the drivers and passengers side? That is what I was thinking the problem may be.
04-12-2021, 05:49 PM | #6 | |
Rep 291
Drives: 2023 BMW M2
