Transmission and Differential Fluid Replacement
04-14-2021, 04:37 PM | #1 |
Novice Enthusiast
15
Rep 75
Drives: 2010 BMW 328i e92 ULEV 90k
Garage List 2010 BMW 328i x-Drive [0.00]
2012 Ford E-350 [0.00] 2009 Cadillac DTS LUX [0.00] 2003 Mercedes Benz ... [0.00] |
My car currently has 90k miles on it and it seems that the previous owners went with the lifetime fluid deal and never changed the transmission fluid or differential fluid. My question is will it cause more harm than good to put fresh fluid in both? I was reading somewhere that it could "shock" the metals inside and cause damage. I just want my transmission and differential to last as long as possible.
‘10 328i 6AT (GM 6L45) AWD
‘03 SLK 230 5AT RWD ‘09 DTS 4AT FWD 12 Ford E-350 |
04-14-2021, 04:43 PM | #2 | |
Rep 298
Drives: 2011 BMW 335xi
2011 BMW 335i xDrive E92 N55 Alpine White\M-Sport /BMS CAF/HPS CAI/VRSF 5" FMIC/VRSF CP/VRSF Inlet and Outlet/VRSF Catless DP/NGK 1-Step Colder Plugs/xHP Stage 1//MHD Stage 2+
04-14-2021, 04:45 PM | #4 | ||
Novice Enthusiast
15
Rep 75
04-14-2021, 04:48 PM | #5 |
Novice Enthusiast
15
Rep 75
You did both fluid changes? Trans and Diff?
04-14-2021, 04:50 PM | #6 |
Rep 298
04-14-2021, 04:50 PM | #7 |
Novice Enthusiast
15
Rep 75
You did both fluids?
04-14-2021, 05:01 PM | #8 |
Rep 298
I only did transmission. Also got a new pan with integrated filter as well (I have the ga6hp19z).
04-14-2021, 05:04 PM | #9 |
Novice Enthusiast
15
Rep 75
Thank you!
04-14-2021, 06:04 PM | #11 |
Rep 1,532
Changing diff fluid will never harm anything. I've heard the same thing above on auto trans (could potentially cause issues if you change fluid) but I think that was more true for older transmissions in the 90's and before. Haven't heard of it on our cars.
2013 335is Mineral/Coral - DR 6466 - DR Mani - PI - Motiv FF - Dodson Clutches - OEM CF Roof - M3 GTS DCT/LSD/DS/Halfshafts/Suspension/Subframe/Brakes/Chassis Bracing F+R - DEFIV Diff Brace - 437M/R888R
2015 X5 35D - 1990 535i [RIP] - 1992 318i Convertible - 2002 540i/6 |
04-14-2021, 06:46 PM | #12 |
Rep 411
Drives: 2011 BMW 328i XDrive
I have a 11 328 xdrive 117k miles. I changed both my diffs 2 weeks ago. I think the previous owners never changed them and the fluid was nasty dark.
My tranny is a manual, ill be doing that as well in the next couple weeks. A manual is a bit less worrisome to me than an automatic I dunno why. Automatic transmissions have a filter that needs changing as well. I'd say change it, but that's me. In the meantime I have vcg leakage, ugh. Time to change that first I guess. |
tgeho_e9215.00 Mosaud19983980.50 |
04-14-2021, 08:47 PM | #13 | |
Novice Enthusiast
15
Rep 75
I was reading that BMW claims a lifetime fluid but only rates "lifetime" as 100k miles. I don't know how much truth there is behind those facts and I'm not sure BMW even claims that but it seems to be a trend that these cars don't get these fluids changed. At least until they go on the forums. Suffice to say I want my trans in my first Bimmer to last at least as long as my n52... Hopefully....
04-14-2021, 09:23 PM | #14 |
Rep 411
Well the n52 will last forever. So at some point your transmission will definitely need flushed.
Another story, my wife had a 2008 Nissan pathfinder. The transmission lines in the radiator (stupid design) cracked open mixing transmission fluid in the coolant and vice versa. Long story short, the cvt automatic gears became delaminated destroying the transmission. Only 1 company currently makes those specific electronic transmissions. It cost me $4,300 to get another put in. 6 months later she totaled the damn thing.... |
tgeho_e9215.00 |
04-14-2021, 09:40 PM | #15 | |
Novice Enthusiast
15
Rep 75
I just didn't want to replace my fluids and screw my diff and trans on my BMW. I really really love this car and want it to last for many more spirited miles.
04-15-2021, 12:57 AM | #16 |
Rep 350
My 2008 E93 has the GM6L45 shared with the Cadillac ATS. Drained, filled, and replaced the filter (no flush!!) at 129k. I felt an immediate improvement. I also had to reset the trans life with my Foxwell NT150 coder to get it to shift properly.
08 E93 N52 170k
tgeho_e9215.00 |
04-15-2021, 02:24 AM | #17 |
Robot
1694
Rep 2,193
I changed the original transmission fluid on my 325i auto at around 235K miles. An independent BMW shop advised against it claiming the same thing that it could do more harm than good. But guess what? It significantly improved my shifting and the car drives much better now, and has been fine for the past two years and 25K miles. It was only a drain and fill, not a pressurized flush.
tgeho_e9215.00 |
04-15-2021, 08:48 AM | #18 |
Hoonigan
6893
Rep 3,001
Drives: '09 328i, '98 Wrangler
Shock the metal? Sounds like whoever told you that was pulling it out of their ass.
The best thing you can do is a drain and fill with new fluid, and get all of the old junk out. The only thing I would stay away from are transmission flushes, especially a power flush, because they can loosen any crud that's caught in the valve body and cause issues. A drain and fill with the proper fluid in both the diffs and the transmission will only prolong the life of the components and the seals. |
tgeho_e9215.00 |
04-15-2021, 09:56 AM | #19 | |
Novice Enthusiast
15
Rep 75
04-15-2021, 09:59 AM | #20 |
Rep 1,322
LOL, shock? That is a new take on the old wives tale.
The origin of "dont change fluid on old whatever" was the theory that it would leak because it would dislodge all of the old, broken down crud that was plugging a gap in a crap gasket. Change your fluid/filter. It serves the same purpose as changing the oil in your engine. Youre getting all of the metal shavings, grit, etc out of the system and putting in a new oil that is now back to specification for what was originally put in the car. More lubrication, no water in it (so no corrosion), etc. My dad fell for the lifetime fluid BS on his E39 and finally gave up and sold it after all of the transmission issues he had because of a blockage that formed in the valve body and damaged it. |
tgeho_e9215.00 CTinline-six6892.50 |
04-15-2021, 10:02 AM | #21 | |
Novice Enthusiast
15
Rep 75
04-15-2021, 10:05 AM | #22 |
Rep 1,322
FYI invest in a good fluid pump, these bastages committed so hard to the lifetime fluid BS they didnt even put a drain plug on the diff, so you have to siphon it out. A good high volume one with a nice thick flexible hose will save you some cussing.
