N51 Sometimes Randomly Won't Start
04-14-2021, 11:40 PM | #1 |
Rep 66
Hi all, I am looking to see if anyone has had this no start issue my car is having occur once every blue moon and recently occurred again last week. This is my sister's car so on the occasions the car doesn't start, it is usually when she is driving it so this is based on what she tells me and what I see through FaceTime. What happens is sometimes her car will not start at all, however the engine just cranks and cranks, but it's like there is no fuel being sent to create spark to start the engine. However, on the occasions where I've told her to wait and try starting again say like (typically 10-30 minutes later), the car will start and run perfectly fine; and the car will continue to start perfectly fine and run fine for months. So this issue has been extremely sporadic.
I was thinking that there would be a code stored for the EKP but when I ran the codes with INPA, the codes that popped up were completely unrelated and the EKP module said OK. Also checked Fuse 70 for the fuel pump and the Fuse looked Ok. So now I'm lost. I know I'm getting pressure and that the fuel pump is working because 1) I can hear the pump/car humming whenever I unlock or open a door of the car and 2) the car is currently running and starting perfectly normal for the past 4 days. (Although there was a long crank earlier today for some odd reason but it still started nonetheless). Sorry for such a long post, but does anyone have any idea what is going on or have had experience with this? I am thinking it has to do with some module or relay that may be going out to cause this issue sporadically. |
04-15-2021, 12:27 AM | #2 |
Rep 350
Hopefully someone has a more specific answer, but I've owned cars where the crank position sensor will fail slowly in a way that doesn't always throw codes, behaving exactly like this.
08 E93 N52 170k
tgeho_e9215.00 |
04-15-2021, 07:09 AM | #3 |
Novice Enthusiast
15
Rep 75
Drives: 2010 BMW 328i e92 ULEV 90k
Garage List 2010 BMW 328i x-Drive [0.00]
2012 Ford E-350 [0.00] 2009 Cadillac DTS LUX [0.00] 2003 Mercedes Benz ... [0.00] |
I'm having this same issue with my car sometimes it's "sluggish" to start but it always does haven't had the issue where it wouldn't. I'm going to watch this thread closely.
‘10 328i 6AT (GM 6L45) AWD
‘03 SLK 230 5AT RWD ‘09 DTS 4AT FWD 12 Ford E-350 |
04-15-2021, 10:51 AM | #5 | |
Rep 66
I hope this isn't the case since I replaced the Crank Position sensor 2 years ago at 97k miles which was a total PIA. However, I remember when the CP sensor failed, the car would start but it would idle extremely sluggish. None of which is currently happening but I hope this isn't the case of a failing CP sensor. Car currently has just under 111k miles. |
04-15-2021, 05:25 PM | #6 |
Rep 13,122
N51 have a problem with the Fuel Tank Hoses self disconnecting.
Do a fuel pressure test. https://www.bimmerfest.com/threads/3...#post-11517585 https://mechanics.stackexchange.com/...but-wont-start There is no sensor for low fuel pressure on an N51 or N52 I believe. So it won't throw any codes. Last edited by ctuna; 04-15-2021 at 05:38 PM.. |
04-19-2021, 01:24 PM | #7 | |
Rep 66
I'll definitely look at the threads you linked to see if I can run some tests on the EKP. Also, I have been receiving Low Battery Charge messages sometimes on the iDrive, could the battery having a low charge be a reason to not send power to the fuel pump or EKP module sometimes? |
04-19-2021, 03:51 PM | #8 | |
Rep 1,893
04-19-2021, 06:56 PM | #9 | |
Rep 4,089
Even if someone had cleared Fault Codes in the DME or EKPS (Fuel Pump Module), each of those Modules has "History Memory" where the last ten fault codes are saved along with some Freeze Frame Data (Snapshot of system conditions at moment Fault was saved, along with Odometer reading in km). So I would suggest viewing the following screens in INPA, and saving any screens showing fault details: 1) INPA > DME (MSV80) > F4 > F1 > F3 Read Fault Memory with Freeze Frame Data 2) INPA > DME > F4 > F3 > F1 Read History Memory 3) INPA > EKPS > F4 > F1 Read Fault Memory 4) INPA > EKPS > F4 > F5 Read History Memory If you are NOT sure how to save ScreenPrints of ISTA Screens as JPG image files which you can attach here, see the attached pdf, "INPA Tutorial Quickstart". George |
04-19-2021, 07:27 PM | #10 |
Rep 1,080
Regarding the starting fluid, I'd open the air box, remove the air filter, and give a short spray. Then jump in and start the car. Sometimes as fuel pumps wear out their brushes, you get intermittent running, because of poor electrical contact.
04-19-2021, 07:29 PM | #11 |
Rep 1,080
With this article as reference, you could also give the fuel pump a wack with a rubber mallet.
https://www.pelicanparts.com/BMW/tec...eplacement.htm |
04-19-2021, 09:02 PM | #12 |
Rep 1,893
The assumption that this issue is fuel pump-related seems unwarranted at this point. By the description given, ('cranks but doesn't start') the problem could easily in ignition circuitry or perhaps a transient EWS fault.
Of course, no matter what it is, it would be very surprising if it did not leave code(s). So list the codes you found. Add CAS to the list of modules you might want to query besides DME and EKPS using the INPA commands suggested by gbalthrop |
04-19-2021, 11:53 PM | #13 | |||
Rep 66
I will definitely check out the other functions for reading the memory when I get the chance though. I usually just stick to read error memory in INPA and not the other F key functions. Quote:
04-20-2021, 06:39 PM | #14 |
Rep 1,893
Kind of what I thought
A10A is EWS challenge/response error. The set of NFRM errors are all about lights out - if you don't have any lights non-functioning, you should recode the NFRM. Don't think this relates to the no start condition though |
04-21-2021, 12:30 PM | #15 | |
Rep 66
Regarding the FRM I had a right headlight bulb that was out and now the right angel eye bulb is out that I need to replace so that could be the reason for those FRM codes. |
04-21-2021, 12:58 PM | #16 | |
Rep 1,893
If these keys are not in alignment, the CAS will activate the starter but the DME will not provide ignition, so the engine cranks but doesn't start. Similarly, if something interrupts communication between CAS and DME during the exchange of key information, a code will be set and the engine will crank but not start. A10A is saying there was a problem with this communication Last edited by dpaul; 04-21-2021 at 01:37 PM.. |
04-21-2021, 07:24 PM | #17 | |
Rep 66
Do you know where I can look first to see what's causing the communication problem in the CAS? |
04-21-2021, 10:07 PM | #18 |
Rep 1,893
Taking a step back, I am confused by your report that A10A is consistently observed i.e. immediately re-appears each time you clear it and yet the vehicle only very occasionally fails to start.
So I did a quick Google scan of A10A reports, and learned two things: 1) The true meaning of A10A is unclear - it may not indicate an EWS issue 2) There were a number of cases with persistent A10A (most but not all with starting problems) but none described a fix When modules give odd errors that are not definitive this is my order of interventions: Unplug connectors and clean Look for corroded grounds or any other obvious wiring issue Reset the module (NCSExpert SG_RESET) Recode the module (NCSExpert SG_codieren, using "default" coding profile) Reflash the module (WinKFP) |
05-05-2021, 05:03 PM | #19 |
Novice Enthusiast
15
Rep 75
I replaced my starter and boom issue gone. Best hope!
BimmerMan242118.00 |
06-20-2021, 12:49 AM | #20 |
Rep 66
Ok I am back as I have finally had further time to run the car for codes using both INPA and ISTA. Also, the car didn't start for my sister a few days ago resulting in why I had to run for any codes.
What I found in ISTA from the tree is an error stored in the EKPS module that did not pop up in INPA. The code is 6293: Control Current Too High. Does anybody know what this means and how I can further diagnose what is causing a surge in the current? Could this explain why her car would crank but does not start due to no fuel being sent to create spark due to this EKPS error? Also I believe this is just a coincidence, but she states that when her car gives her this issue, it is usually always on a hot day. To also add, car has ran fine for her for the past three days and I just checked today and car starts up fine and engine is running smooth. I will attach photos of the error code results as well as a test I ran on the CAS system to try and rule out any communication issues between the key, CAS module, and the DME. |
06-20-2021, 01:13 AM | #21 |
Rep 66
I think I may have found the reason why the car has issues with starting now. My sister has provided me with extra details when the issue occurs and it sounds like the EKP module is overheating causing no fuel to be sent to the engine. I just found a YouTube video with someone who had a similar issue and will try to do add thermal padding to the module and see if it helps the module. Hopefully this works and if anyone else runs into this issue, try this.
https://www.youtube.com/watch?v=Fjrd...oE9XChicagoE9X |
06-20-2021, 04:23 PM | #22 | |
Rep 4,089
That SWAG is particularly likely if the "Crank, NO Start" situation happens after car has sat without engine running for a longer period, as opposed to being OFF for only a few minutes to a few hours. In that scenario, time NOT operated as opposed to heat developed in the tank or by normal pump rotation is the variable that explains what otherwise may appear "random". That theory is supported by the Freeze Frame Data or Fault Details shown in your 2nd ISTA Screen. INPA and ISTA provide SO MUCH data, that you can easily overlook major CLUES which are contained in the data. In this case it isn't Flashing "Your Pump is STUCK" in Red Lights, but the data basically indicates that. Just to walk through that Data together: 1) The Definition of EKPS (Fuel Pump Module) Fault Code 6293 is "Control Current Too High". 2) When that Fault Code was saved in EKP Module Memory, it also saved certain system conditions, as measured by the EKP, at the INSTANT the fault was saved, providing a "Snapshot" of those conditions at that time. 3) Motor Current (draw) Electric Fuel Pump = 18.2 Amp. 4) Motor Speed Electric Fuel Pump = "0 1/min"; THAT'S ZERO RPM, rotation = NADA! STUCK while drawing 18.2 Amp Current. Watts (used to rate heaters ;-) = Volts x Amps. In YOUR case, instead of pumping fuel, your pump has turned into a HEATER (on that one occasion in the past) producing 185.64 Watts of heat, 'cuz it could NOT do work and pump fuel. 5) The fault was NOT currently present when you read fault code; the Pump Current draw value (Amps = 18.2) was too high, out of range = implausible; the German text NOT translated in your ISTA version = Fault would NOT (Kein) cause a Warning Lamp (MIL) to light (on Instrument Cluster). 6) The Fault was saved during Starter Cranking (Engine Speed = "200 1/min" or 200 RPM. No reason to check CAS Module, the Starter Cranked the engine, but the Fuel Pump was NOT pumping. Vehicle speed was Zero km/h, and your "Desert Air" was 39C. 7) The Reason Battery (Terminal 30) Voltage was only 10.3V, is NOT because the Battery was discharged. Battery voltage BEFORE pressing the START button was probably in 12.4V range, and the roughly 2.0 Volt DROP during Starter Cranking is Normal Voltage Drop due to Starter Draw. I can't be quite certain WHY the Fuel Pump only occasionally refuses to turn. Perhaps someone who has conducted an "Autopsy" on a failed pump can provide that answer. Something to do with failing bearing, impeller contact, brushes (if any). George |
