04-15-2021, 12:49 PM | #1 |
Rep 161
Reverse bulb replacement - fit issue
I'm ashamed to be asking this but there must be something wrong with what im doing:
I was able to remove the old reverse blub (broke the weird brown plastic clips around it) and now im trying to fit in the new buld, but the new bulb just sits there loose... its like the brown plastic from the old bulb needs to be fitted on it? or i bought the wrong bulb? Can someone plz guide me. Here's the new bulb in attachment. I have a 2014 435i F32 Thank you! |
04-15-2021, 01:58 PM | #2 |
Rep 614
Drives: 2016 F36 M Sport
I'm so glad I'm not the only one that got confused with this too. I did the exact same thing as you when I swapped mine out!
You'll need to find bulbs with the same base as the one you removed. Try searching for pw24w instead of pw16w, and you should find results with the correct base.
2016 BMW 428i Gran Coupe, M Sport, Glacier Silver Metallic
mazen22227.50 |
04-15-2021, 03:03 PM | #3 |
Rep 16,151
Wrong bulb. The plastic clips around the base of the bulb that you broke off are part of the bulb. If you're trying to use an LED bulb the base must look the same as this.
https://www.turnermotorsport.com/p-1...uine-bmw-part/ There may not be any LED that uses the PW base, it's a pretty rare bulb. |
mazen22227.50 |
04-15-2021, 03:17 PM | #4 |
Rep 614
I got these from iJDMTOY on Amazon, but the build quality is trash. Luckily they haven't given me any trouble yet, I've had them for just over a year.
https://www.amazon.com/dp/B0101BT3UA...UTF8&psc=1
mazen22227.50 |
04-15-2021, 07:35 PM | #5 |
Rep 161
Awesome. I'm getting these
LUYED 2 X 900 Lumens 12-24v White color Super Bright 3014 78 SMD 3056 3156 3057 3157 LED Bulbs , Back Up Reverse Lights,Brake Lights,Tail Lights https://www.amazon.ca/dp/B01D8DJN30/...STVR4S4GZKYWDC Thanks guys! |
04-16-2021, 06:21 AM | #7 | |
Rep 161
If I apply that filter only the previous model I bought shows up. So there must be something wrong with their filter. The base does look like the one you quoted and it comes out with the PN the first post recommended. So I’m optimistic I’ll post follow up. They are arriving today |
04-16-2021, 07:48 AM | #8 |
Rep 16,151
That base isn't even close to the link I posted. This is:
https://f30.bimmerpost.com/forums/sh....php?t=1766799 |
