BMW X5
      04-18-2021, 12:08 AM   #1
LexxM3
LexxM3's Avatar
Drives: E46M3, G05X5
2019 X5  [0.00]
While apparently BMW modern interior designs are "better" in this respect than all the other major luxury cars, it is still the case that you often need to look (dangerously) away from the road to activate useful functions like any of the 8 shortcut buttons and the main control panel buttons. I've been looking for a while for Braille glue-on dots, but I've come to the conclusion that those do not exist. I finally found something that seems to work well, however — self-adhesive "rhinestones". In case others find this of use, the following, for example, have the smallest I could find 2mm dots and below are a few pics of some that I installed:
https://www.amazon.ca/dp/B07M6NDG4X/
https://www.amazon.com/dp/B07M6NDG4X/
I installed dots on PDC camera button, Sport button, ECO button, 2/4/6/8 shortcut buttons. The double sided glue backing that came with these seems to be holding for now, didn't need extra glue (clean the surface with dilute alcohol first, like any tape or glue job).
These should have been molded into the original BMW plastic in the first place ...
G05 X5 x40i (04/2019 mfg, Canada) on S18A-19-11-540
sahajesh2294.00
Paladin15556.00
Cooltones241.00
GrussGott18183.50
      04-18-2021, 03:46 AM   #2
Wild Blue
Wild Blue's Avatar
Drives: 2021 X7 M50i, 2004 330i w/ZHP
Thanks, man!
Like a rhinestone cowboy. Good idea.
Cross-continent road trip journal from BMW PCD to Alaska in new X7 M50i in this thread HERE!
New EVEN BIGGER road trip in X5 from BMW PCD to Alaska NOW ONGOING LIVE IN THIS THREAD!
Wilderness road trip journal to Eastern Alaska in this thread
And road trip journal to Denali and the Arctic Circle here in this thread!
      04-18-2021, 08:30 AM   #3
sahajesh
sahajesh's Avatar
United Kingdom
2294
Drives: 2021 G05 X5 40i Tanzanite Blue
Should use a Swarovski set for "Crafted Clarity"
Wild Blue3683.50
      09-16-2021, 08:03 PM   #4
LexxM3
LexxM3's Avatar
2019 X5  [0.00]
As an update and for the record, most of the 2mm dots eventually fell off and I am now using 3mm dots from the same set. Seems to be more sturdy (greater adherence surface area) and looks just as good.
      09-20-2021, 09:11 PM   #5
SmartSaves
X5 Enthusiast
SmartSaves's Avatar
Drives: 2021 X5
2021 BMW X5  [10.00]
To add to your awesome idea: I developed muscle memory the following way to select the driving mode buttons without looking :
1. Using the index finger find/touch the front edge of the parking brake.
2. Slide the finger left (adaptive).
3. Next button is Eco Pro, this is sunken a bit.
4. Comfort and Sport has a ribs.
Seems like lot of steps, but in practice it's pretty quick to get the hang of it. Sometimes I also use voice commands to change driving modes.
2021 X5, Excellence, M Sport, DHP, DAP, RSE, MW, Merino.
xbimmers
