E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Bmw Oil on valve cover
Reply
      04-18-2021, 03:10 AM   #1
2one3E90
2one3E90's Avatar
2422
Drives: Bmw 330i and Bmw 328i
2010 BMW 328i  [10.00]
2004 BMW Z4   [9.67]
2006 BMW 330i  [10.00]
I see oil in this area on the valve cover and a slight shimmer in some areas. Is this from bad top up or is my oil cap leaking? It is the original one from 2006. The oil is very thick when i wiped it off. Also one of my coils had the clip slightly out. I clipped it back in and it looks normal now but do they get loose by itself?
      04-18-2021, 08:40 AM   #2
CTinline-six
Hoonigan
CTinline-six's Avatar
Drives: '09 328i, '98 Wrangler
Likely from someone spilling while topping it off/filling. Wipe it up and see if it comes back.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park
Mosaud19983980.50
2one3E902422.00
Jesda144.00
      04-18-2021, 12:15 PM   #3
E92_William
E92_William's Avatar
Drives: 2008 BMW 328xi
I think that could be the oil cap. Mine can sometimes get the same and it's grimy around the oil cap.
Airplane Mechanic
BMW Masochist
2one3E902422.00
      04-19-2021, 05:53 PM   #4
Jesda
Drives: 2008 E93 N52 78k
Replace the cap. I replaced mine today for this exact issue.
Get the newer design with the round cap. I paid $34 at my local dealer.
https://www.fcpeuro.com/products/bmw...IaAiICEALw_wcB
08 E93 N52 170k
      04-20-2021, 09:27 PM   #5
mainbearing
Drives: BMW 328i
I replaced the gasket but still had the seepage on the 2007. I do need to re-seal the oil pan gasket (just needing to find the time), and probably are losing vacuum as a result of that, leading to the oil seepage at the cap.
2one3E902422.00
      04-25-2021, 10:42 PM   #6
2one3E90
2one3E90's Avatar
2422
2004 BMW Z4   [9.67]
Can the oil ever reach to the coil packs and important parts? There is like some holes or passages on the valve cover that it goes down to.
Reply
e90post
