E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > ///M S55 oil filter for n52 n54?
Reply
      04-19-2021, 03:43 AM   #1
F31B48
F31B48's Avatar
278
Drives: BMW G21 E61 LCI
Stumbled across this oil filter today. Genuine BMW part, exactly the same dimensions as our n52, n54 filter, but this filter is only listed for M3, M4 with S55 engine. I'm guessing it would have better filtration than the standard one?
Thoughts on using this in our n52s and n54s?
      04-19-2021, 03:45 AM   #2
F31B48
F31B48's Avatar
278
      04-20-2021, 02:27 AM   #3
JonOhh
JonOhh's Avatar
Drives: 06' 330i
Very interesting find.
I would not assume it to have better filtration properties automatically- if there is any performance difference between the non M part it may be the other way around (reduced filtration effectiveness traded for a better flow rate at a given pressure differential) for high RPM use.
In this case there would be a different filter media, but potentially not a visible one. It looks slightly different on camera but that's not enough to be certain.
If there are more pleats it's possible for it to support the same particle size (filter effectiveness, essentially) AND a higher flow rate at a given pressure differential, so if you wouldn't mind counting and doing a visual comparison to another non M filter- you may be on to something if you spot differences. Make sure they're the same manufacturer if you are willing to do this, however.
Definitely keep us updated! Cool find.
      04-20-2021, 05:40 AM   #4
Pittz1
2018 M3 ZCP / 06 330xi
211
Drives: 330xi 2006 / 18 M3 ZCP
If you dont want it, just send it my way. I could use it on the F80
Reply
e90post
