Car overheating with no check engine light or codes
04-19-2021, 04:18 PM | #1 |
Rep 4
Hello,
I have a 2007 328xi. Recently I have had problems with overheating. I looked up common causes for this and found the most probable to be the water pump or thermostat. However, I have no check engine lights or obd2 codes that would point to this. I looked for leaks, but didn't find any. Is it possible that the water pump or thermostat is bad but is not giving a check engine light? Let me know if anyone has an idea Thank you. |
04-20-2021, 02:15 PM | #2 |
Rep 3
Sudden Overheating!
Hi LRokosky,
I drive a 2007 335i sedan. My car overheated today with no prior warning or symptom. It overheated and showed a yellow warning, then a red overheat warning with reduced performance. The car did not respond to the throttle and it moved like a slow turtle The temprature reached 250°F and I turned it off right away. I had it taken to a local expert - https://www.instagram.com/bavmotors/ Car was tested, water pump needs replacement. |
04-20-2021, 03:08 PM | #3 |
Rep 1,772
Drives: Bmw 330i and Bmw 328i
I wonder what happen to cars without temp gauge
04-20-2021, 06:44 PM | #4 | |
Rep 323
Luis56194.50 |
04-21-2021, 09:54 PM | #5 |
Rep 462
04-27-2021, 02:24 PM | #6 |
Rep 4
Fixed!
I replaced my water pump and thermostat, and the car seems to be working fine now.
MightyMouseTech4337.50 |
04-27-2021, 02:40 PM | #7 | |
Rep 7,215
The dumb thing is hiding the error codes for the pump. There's no CEL or SES for them - the only way to see them is with a BMW code reader. |
nsjames2443.00 |
04-27-2021, 04:52 PM | #8 | ||
Rep 269
Try running the water pump with the engine off, if it doesn't run, there's your answer. |
04-27-2021, 07:16 PM | #9 |
Rep 815
Exactly. Most dashboard temp gauges don't reflect the actual coolant temp but rather just go to the middle position if the temp is within an acceptable range. Auto manufacturers years ago figured out that a variable temp gauge that read/reflected the actual coolant temperature was too confusing to operators. Which is why most also went for the "idiot light" (named that for a reason).
04-28-2021, 09:28 AM | #10 |
Rep 1,080
LR, dumb question, but how did you know your car overheated.
I'd buy a cheap hand held infrared temp gauge, and get a feeling for normal underhood temps. If you have another vehicle, that would be a good place to start. All cars are about the same. https://www.amazon.com/Infrared-Ther...s%2C171&sr=8-3 |
04-28-2021, 12:02 PM | #11 |
Rep 6,196
04-28-2021, 06:48 PM | #13 | |
Rep 1,843
