Ladies and Gentlemen, Mesdames et messieurs, Meine Damen und Herren... 300,000 miles
04-21-2021, 07:44 PM | #1 |
Rep 2,835
Would have hit the mark last year except I have been teleworking since March 2020.
2007 BMW 328xi E91 in Barbera Red |
16
Mosaud19983980.50 IllSic_Design2124.00 mecheng771007.00 3PedalJake2613.50 tcphoto3556.50 jsunma653.50 tgyberg87.50 Buug95918075.00 dmatre673.50 e90yyc2426.50 E92_William1306.00 CTinline-six6892.50 Vivek.1367.50 georgewny42.50 Clammy322.50 POBEP374.50 |
04-21-2021, 07:47 PM | #2 |
Rep 1,272
The judges are conferring on whether to accept the 000.3 or if 000.0 is required.
04-21-2021, 07:53 PM | #4 |
Rep 2,835
Probably around $9k. That would cover the normal maintenance (oil, tires, brakes, rotors, plugs, struts, bushings, rear wheel bearings, etc) plus 1 water pump / thermostat, 1 alternator and 1 starter and replacing the original CCC with a CiC. Except for 1 oil change, it's only had BMW oil in it.
Mosaud19983980.50 |
04-21-2021, 07:57 PM | #5 | |
Rep 2,660
Drives: 2019 BMW 540
I brought mines at 67k miles in 2019 put about $2k into it last year for oil leak repairs (VCG, OPG) and suspension stuff like thrust arm bushings. |
04-21-2021, 08:04 PM | #6 |
Rep 2,835
Bought it in 2010 w/ 33k miles on it from BMW of Asheville. A lady traded it in on a brand new bright red X3 and it had sat on the lot for several months. They knocked several many thousand off of it, made it a CPO w/ 100k warranties and gave me a good price for my oil guzzling A4.
Mosaud19983980.50 |
04-21-2021, 08:07 PM | #7 | |
Rep 2,660
I hope I can make it to 100k I'm hardly at 73k miles |
Greyfox1207.50 |
04-21-2021, 08:09 PM | #8 |
Rep 2,660
Wait a minute, you only spent $9k in the span of 11 years?
Man, must've did all the work yourself |
04-21-2021, 08:29 PM | #9 |
Rep 2,835
Mosaud19983980.50 |
04-21-2021, 09:48 PM | #11 | |
Art Collector
2427
Rep 3,450
I’ve almost certainly over-maintained my car, but I’ve put about $6-7k USD into over 3.5 years! That said, I’ve knocked off a lot of things that shouldn’t need to be done again or for a long long time. Congrats Greyfox .
Mosaud19983980.50 Greyfox1207.50 |
04-21-2021, 09:56 PM | #12 |
Rep 2,660
This is why I buy my stuff of FCP. Only pay once
04-21-2021, 10:09 PM | #13 |
Art Collector
2427
Rep 3,450
Agreed!
I feel supremely stupid though. I buy 90% of my stuff from FCP, but for reasons I can’t explain (okay, I can: FCP was more expensive and I was being cheap) I bought my shocks and front control arms from RockAuto like a true idiot. In hindsight that was THE definition of penny wise, pound foolish.
04-22-2021, 09:59 AM | #14 | |
Rep 5,022
04-22-2021, 10:32 AM | #15 | |
Art Collector
2427
Rep 3,450
The more I think about it the more I truly do not understand how they can afford to have that policy. I would love to see their books.
Mosaud19983980.50 |
04-22-2021, 10:52 AM | #16 | |
Rep 5,022
Mosaud19983980.50 |
04-22-2021, 11:54 AM | #17 | |
Rep 14,829
Same with my hood and trunk struts, ECS was the best and then my TPMS Bavauto was. It really depends on the part. Dealer damaged my car? I told FCP the dealer did it, and they won't admit it (at the time), is it still covered? They said yes, it is! |
04-22-2021, 06:24 PM | #19 |
Rep 2,835
Thanks
And thanks to all the other posters. I would of hit this probably a year ago, but I have literally been teleworking since last March and have only gone to work 3x since then. It's getting ready to be pulled into the garage and have several things done like new plugs, oil change, transmission fluid change and replacing the rear lower center suspension bushings with Strongflex ones. |
04-22-2021, 08:04 PM | #20 | |
Rep 5,022
Mosaud19983980.50 |
04-22-2021, 09:21 PM | #21 |
Rep 358
Tires
Curious what tires you high mileage guys prefer? My rear PS2s only lasted about 16k miles before replacing and then I went through Hankook Ventus V12s at about the same rate. Each time it was the inside edges from I guessing the negative camber on my sport 330i (alignment shop has maxed out the camber cam - ~-1.5 degrees).
I'm currently on PS4s, but rarely drive it since it was getting a little pricey for annual rear tire replacements.
2006 e90 330i | Black/Terra | 6MT | ZSP | ZPP | ZCW
04-22-2021, 11:13 PM | #22 | |
Art Collector
2427
Rep 3,450
I’m just curious if you’d suggest replacing anything else at higher mileages, and am also curious whether Greyfox is still on original rear components (except shocks)? I’ve inspected my rear control arms a few times now and as far as I can tell everything seems pretty tight, even at 200k miles . talisman311 Wow. Yeah, that would get expensive! I just put on DWS06 Plus’ and they’re good. Clearly not in the same league or category as PS4s, but if you’re not driving your car because tires are costing you too much... maybe time to switch tires
Efthreeoh17438.00 |
