Bimmerpost
4 Series
Technical Topics B48 4-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications 330E Engine Lottery
      04-24-2021, 02:26 PM   #1
Westyfield2
Drives: F83 Competition
330E Engine Lottery
Has anyone worked out the B48B20A or B48B20B logic? Definitive rule?
Is it saloon vs touring? RWD vs xDrive? Stock car vs custom options build? Trim level? LHD vs RHD? Etc.
      05-11-2021, 02:42 AM   #2
MarkoSK
Drives: BMW G20 330eX
Someone said in another thread that xDrive vehicles have the A motor. However, it hasn't been officially confirmed.
      05-20-2021, 07:38 AM   #3
sd_dracula
Drives: 2020 G20 330e
Check the label on the engine
https://g20.bimmerpost.com/forums/sh...2#post27096582
      06-01-2021, 02:34 PM   #4
hottroc
Drives: BMW 330e
They put the B engine in the M-Sport variety.
      06-02-2021, 05:47 AM   #5
ovesund
Sweden
82
Drives: i4 eDrive40, i3 60Ah
I have a B engine and no M-sport package so it really doesn't seem to be a pattern
Perhaps they just grabbed what they had nearby...
      06-03-2021, 03:10 PM   #6
Maiens
Drives: 2021 G20 330e M-Sport
it do seem really random, the same day as i got mine someone else got one and we talked for like 15 min and found out the i got the B and he have the A. both are m-sport so seems really random.
      06-03-2021, 03:37 PM   #7
bquatt
Drives: 2020 330xi m-sport
So I need to clear the air - what's the difference? I have a B46D 330i as most if not all in the USA do, but why the prodding into the engine code? Is there really a difference between engines with different alpha characters? Besides the obvious numeric B46/B48 SULEV differences..
      06-05-2021, 12:06 AM   #8
Knifeedge2k1
Drives: BMW G30 520i 2019
Yes
If you are in the US and have a non hybrid 330 you have the B engine
The distinction between A and B are as follows
The A engine is used exclusively in 20i and 30e models, the B engine is used in both 20i,30i and 30e models. The engine differ in many of their components which affect how much you can push them with stock parts (the most obvious and major difference is the A engine utilizes higher compression pistons which limit the boost you can make)
When the B engine when utilized in the 20i application it's detuned in purely software compared to the 30i application
bquatt218.50
      03-06-2023, 10:48 AM   #9
KNUTZ4s
BIMMER LOVER
KNUTZ4s's Avatar
I am considering buying a 30e and want to know if there are any differences, and also, if there are any ways to accurately tell if I have the B or the A variant.
Is bimmercat 100% accurately if I go and check the short engine code? I also have access to TecDoc Catalogue as I own a car parts store, would it be more accurate?
      03-08-2023, 05:01 AM   #10
gorthol
gorthol's Avatar
Spain
64
Drives: BMW 330e 2021
2021 BMW 330e  [0.00]
Any 330e from 2022+ is 100% sure going to have the "A" engine. The engine code will be in the engine bay, a little lower and to the left after you remove the beauty cover, not hard to find.
Bimmercat is probably not accurate since AFAIK they stopped updating some time ago when BMW starting to ask for money for that information.
      03-10-2023, 04:59 AM   #11
dkulp
Drives: 2023 330e
2023 BMW 330e  [0.00]
Outside the US, that is possibly true. The 2023 330e I took delivery of in January has the B engine (US 46 version). The 320i isn't sold in the US so it's likely easier to consolidate to the single 46B engine for all US cars.
      03-10-2023, 05:44 AM   #12
gorthol
gorthol's Avatar
Spain
64
Note the 46 can be both the A or B (it was C or D for the 46 or the other way around? Don’t remember), what is the exact code on your engine bay?
      03-10-2023, 05:48 AM   #13
gorthol
gorthol's Avatar
Spain
64
I just saw that BMW USA list the 330e compression ratio as 10.2 (which is really the only difference because of the piston heads) so it looks like you lucky bastards are getting the B.
      03-13-2023, 09:54 AM   #14
AirVetra
Spain
Drives: F16 X6 m50d
Any news with getting 20b engine in Europe?
I checked 5 cars at German market dated 07-10/2020 almost all of them come with 20a:-(
I'm looking for xdrive touring and cannot find any... Seems have to switch to smth like m340d while was so excited with this PHEV...
      03-14-2023, 08:17 AM   #15
EvanL
Drives: '07 335i, '23 330e
Same; 2023 330e. Nobody has mentioned the country of origin--it wouldn't surprise me if Mexican production only has the B variant available.
E92 335i/G20 330e
      05-02-2023, 02:21 AM   #16
gorthol
gorthol's Avatar
Spain
64
Originally Posted by EvanL View Post
Same; 2023 330e. Nobody has mentioned the country of origin—it wouldn't surprise me if Mexican production only has the B variant available.
From this year it seems all G20s are coming from Mexico, even European ones, so we’ll see what happens.
      02-20-2024, 12:29 AM   #17
HiFi
Drives: 2023 BMW M3
any update on this - do we know which engine 2023 330e is coming with since the change to mexico production?
      02-29-2024, 11:55 AM   #18
Dionissis
Dionissis's Avatar
Greece
Drives: BMW 330e 2023
Order for EU market of 330e LCI 2023Y from Mexico Production line.I checked the engine bay and the label says "A".
g20
