Help With Pre-LCI AHL Adjuster Problem
04-28-2021, 03:24 PM | #1 |
Rep 624
I have a pre-LCI AHL headlight assembly (Left-hand side) with one of the manual adjusters out of the socket, and so far no matter what I've tried, I CANNOT get it to pop into place!
The first pic shows what I'm talking about. The second one shows the area where it's located, and the arrow points to the adjuster screw. ANY help would be GREATLY appreciated, because if I can't get this back in place,t he headlight is unusable... Thanks in advance. Cheers! |
04-28-2021, 05:03 PM | #3 |
Rep 1,183
For a pre-LCI, the exact procedure may be different, but I had the same issue with my LCI.
Try seeing if the entire mechanism with the light itself will move into position. You’ll need two people, but then try popping the adjuster into place. You’ll need to angle it down, into the housing. Once again, though, this for an LCI, so I’m not sure if it’s the same process. |
04-28-2021, 06:42 PM | #4 | |
Rep 624
On the other one, I had to re-seat the automatic leveling servo. That was pretty easy, actually, and I wish that's all I had to do for this. I'm starting to wonder if the socket is broken/worn out... Anyone know of a way to transfer the guts from one headlight assembly to another? I have my original AHLs, with severely yellowed lenses, which was the reason for buying these ones, which have pristine lenses... Cheers! |
04-28-2021, 11:47 PM | #6 | |
Rep 624
I'm not confident in getting a perfect seal, or not wrecking the headlight when removing the lens. Thanks for the suggestion, though. Cheers! Last edited by Clammy; 04-28-2021 at 11:52 PM.. |
