EKP3 plug and play overheating solution
04-29-2021, 01:22 PM | #1 |
V8 Bait
207
Rep 769
Is there any market for an EKP3 with heat sinks, thermal pad upgrade, and a fan attachment that comes with simple instructions to install? I am willing to produce them for those in need especially as more and more owners demand higher fueling requirements.
Broke AF
04-30-2021, 09:59 AM | #2 |
Rep 1,232
Not sure there is a huge market for it since its a super easy DIY with parts easily sourceable thru amazon.
Not to mention replacing the EKPM requires it to be recoded which is more of a pain than doing the actual DIY yourself. |
04-30-2021, 10:59 AM | #3 |
V8 Bait
207
Rep 769
Any EKP that has previously been used on a N54 will not need to be coded.
Broke AF
04-30-2021, 02:02 PM | #4 |
Rep 3,731
I thought here was already someone doing just what you are talking about....I think there are even some posts on here from him. He sells a kit that comes with a fan and some other stuff.
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
07-17-2021, 08:00 PM | #5 |
Rep 7
Hi friends,
today I replaced my original E90 EKPM3 7218339, by used EKPM3 7276046 without any coding needing. No errors, no failures. Plug and play. My car's engine was stoping in motion without any reason, no troublecodes, no errors. But I will the test car outside my garage tomorrow. I turned on the engine, It worked witout any problems after the swap, readings with NT510 with BMW software ok. Best regards, Paulo E90 LCI 325i Brazil |
07-17-2021, 09:21 PM | #6 |
No one sleep in Tokyo
945
Rep 1,507
Drives: 2011 E90 328i//1995 E34 530i
My engine died once the other day for the first time while lightly driving at 40mph. Wouldn't crank back over for about 15 minutes. Have a new BimmerGeeks cable on order so I can read codes from EKP module. I suspect I have the same issue with overheating/dying EKP module.
When doing research I've seen some DIY jobs with people putting motherboard thermal strips on the back of the EKP silicon where it meets the backing. Maybe try that. Also saw some guy put a small laptop-esque fan attached to his module with some custom splicing - seems like more effort/risk than it's worth unless you are pushing the stock fuel module way past it's limits.
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
07-18-2021, 08:50 AM | #7 | |
V8 Bait
207
Rep 769
Broke AF
07-19-2021, 10:58 AM | #8 | |
945
Rep 1,507
01-05-2022, 11:06 PM | #9 |
V8 Bait
207
Rep 769
Sorry for the super long wait. I sold my car and was promised help testing with a friend but that never happened. A like-minded individual has offered to help and after much brainstorming we have a plan in motion. Over the coming weeks we will be temperature testing an EKPM3 with controlled and repeatable data collection in both factory and modified units to see the improvements. We are also looking into clean wiring (literally just a power and ground) that looks good and works flawlessly. No vampire clips necessary! No splicing!
Broke AF
