05-04-2021, 12:05 PM | #1 |
Rep 2,147
Drives: F80 M3
Micro Cracks F30 Xenon adaptive
I have succumbed to the micro cracking that plagues all early f30s. what options do I have for replacement? Any suggestions?
Currently debating between: 1. ordering a new set of oem headlights off ebay 2. Upgrading to LED LCI headlights and dealing with wiring and coding 3. Sending them out to a company like OSS or Bavgruppe to get customized Have any of you dealt with the custom companies or have any of you purchased lights on ebay or can suggest another option? I was hoping by this point that Depo would have released the LCI upgrade but it looks like that may never happen.
Instagram: http://instagram.com/e90nate
05-11-2021, 02:56 PM | #2 | |
Rep 377
I'm sure the other vendors you mentioned could also swap the lens for you. I personally have worked with BayOptiks, I had them do a projector clear lens swap (different from the housing lens that you need). I had the option to replace my housing lens but I chose not to. The housing lens itself is not expensive to replace though. The cost is in the labor of removing the old lens and sealing it back up, but it'll still be cheaper than buying an entire headlight set. Although, some might say that if you are opening up the headlight might as well have custom work done. You could totally do that as well, and either OSS, BavGruppe, or Lightwerkz could help you with that. Just make sure the quality they seal the lens back is good. (My seal was a bit messy from BayOptiks, tbh but so far no leaks so that's good). Regarding switching to an LCI led set, personally I think the adaptive HIDs perform better, have a better beam pattern, and are brighter than the LCI leds, especially when the beam height is adjusted properly. If you do have someone open up your headlights, you could consider a projector clear lens swap like what I did - really create a crisp cutoff and widens the beam even more. Goodluck!
2014 BMW 328i, 6-speed Prem / Nav / Drivers Assist / Heated Seats / Lighting |
Onizukachan1124.00 |
05-12-2021, 07:49 AM | #3 | |
Rep 2,147
Drives: F80 M3
Do you happen to have any pictures of your current set up and the set up that you had done by Bayoptiks? They were also on my list, the biggest downfall for them right now is the turnaround time with no headlights in my vehicle.
05-12-2021, 01:20 PM | #4 | ||
Rep 377
Here are some photos of the light output prior to my projector clear lens swap and after. I also upgraded my xenon bulbs from OEM to Osram Cool Blue Boost, which gave a whiter output (closer to LED color). First photo is comparing the two (note the sharper cutoff and slight blue color at the cutoff for the "after"), next two photos are OEM, and the last two are output shots with Osram CBBs.
e90Nate285.00 |
05-12-2021, 01:25 PM | #5 |
Rep 377
Also, here are a couple of my previous threads on my experience:
Projector clear lens swap impressions: https://f30.bimmerpost.com/forums/sh....php?t=1596618 Osram CBI vs. Osram CBB comparison: https://f30.bimmerpost.com/forums/sh....php?t=1601069 Also, just to clarify.... what I did with my headlights is different than what you're looking for. I did a projector clear lens swap, but did not swap out my actual headlight housing lens. But, if you do swap out your headlight lens and your budget allows, I do recommend doing a projector lens swap for the clean cutoff in the beam pattern!
e90Nate285.00 |
05-12-2021, 01:35 PM | #6 | |
Rep 2,147
Drives: F80 M3
chuckles01188.50 |
05-12-2021, 05:24 PM | #7 | |
Rep 144
There are also those headlight modification service providers you mentioned, which involve trading in your headlights, for a set of pre-modded ones, or having the shop mod your headlights and mail them back to you. I think, they would make more sense, if you're going for a mod that makes your headlights stand out (different style or shape of DRLs, etc) I've had those LED headlights installed for a little over 4 months now, with no issues so far. |
05-12-2021, 08:40 PM | #8 | ||
Rep 2,147
Drives: F80 M3
05-13-2021, 12:26 PM | #9 |
Rep 144
I've attached a few pictures of both the headlights and retrofitted LCI taillights.
They're just not as bright looking during daytime than they are after sunset. I've installed the taillights nearly a year ago, and they've been impeccable, fitting perfectly, no condensation, or whatsoever (they're VLANDs, so they're pretty much PnP, and come with connectors for both pre and LCI models). As for the headlights, as mentioned before, they're also PnP, and DIY friendly, requiring no additional coding. Since I've installed fairly recently (early february), I think it's still a bit early to vouch for them, but they're definitely on par with OEMs in terms of workmanship and build quality. BTW, please mind that headlight lenses were dirty when the photos were taken. These two mods definitely take a pre LCI to the next level, and for less than 1.1k combined (350 for the taillights, 730 for the headlights), for both purchases, it's money well spent, in my book. |
e90Nate285.00 |
05-13-2021, 02:54 PM | #10 | |
Rep 2,147
Drives: F80 M3
If you ever take any more pics please post them, you should do a thread about the lights, I couldnt find any info in the groups about positive or negative experiences. and the fact that these are auto levelling is even better as i currently have adaptive headlights
05-13-2021, 03:48 PM | #11 | |
Rep 144
Regarding tail lights, you might also consider GTS style OLED tail lights, which weren't available yet when I bit the bullet last year. They seem to be more aggressive and trendier. Can you post pictures of your cracked headlight lenses? Mine were cracked at the top of both lenses, and as such they were barely noticeable. |
05-14-2021, 09:52 AM | #12 | ||
Rep 377
05-14-2021, 10:22 AM | #13 |
Rep 2,147
Drives: F80 M3
yeah that is important to me. I am thinking I will end up eventually sending them out for customization.
05-14-2021, 12:09 PM | #14 | |
Rep 2,648
Bootmod3, CTS Catless DP, B58TU HPFP, XHP, BM3 Flexfuel Kit
chuckles01188.50 e90Nate285.00 |
05-14-2021, 02:53 PM | #15 | ||
Rep 2,147
Drives: F80 M3
05-15-2021, 10:51 AM | #17 |
Rep 2,147
Drives: F80 M3
What shop? Gtaretrofits?
05-16-2021, 04:58 PM | #18 |
Rep 2,648
05-17-2021, 08:36 AM | #19 |
Rep 2,147
Drives: F80 M3
I will reach out to them thanks!
05-19-2021, 09:19 PM | #20 | |
Rep 426
05-19-2021, 09:49 PM | #21 | ||
Rep 2,147
Drives: F80 M3
