Engine Wear
05-04-2021, 06:50 PM | #1 |
Rep 169
Engine Wear
I ran into an emergency... I drove my car on the highway for about 15-20 minutes to get where I needed to go. I proceeded to sit in the parking lot with the engine running for 20 more minutes and this is where the problem starts 🤦🏽*♀️ I cut the car off for 5 to 10 minutes and instantly turned it back on & started accelerating hard because it was a really bad family emergency and now I’m worried I got to like 110mph on the way back and started smelling burning but i assume that always happens at high RPMs plus my valve cover gasket doesn’t leak on the manifold and never has? Is it normal to smell burning ? And did I do any damage that could cost a ton
05-04-2021, 06:57 PM | #2 |
Rep 852
Probably just an oil leak, have a check for the common gaskets that go. Back of the valve cover can leak without being visible and smell
Airplane Mechanic
BMW Masochist |
05-04-2021, 07:44 PM | #3 |
Rep 1,532
One time I drove my e34 535i at over 100mph for over 2hrs straight and when I arrived the engine was visibly smoking from the side of the block with no obvious source. I put another 20k on it (up to 205k) and it was perfectly fine.
2013 335is Mineral/Coral - DR 6466 - DR Mani - PI - Motiv FF - Dodson Clutches - OEM CF Roof - M3 GTS DCT/LSD/DS/Halfshafts/Suspension/Subframe/Brakes/Chassis Bracing F+R - DEFIV Diff Brace - 437M/R888R
2015 X5 35D - 1990 535i [RIP] - 1992 318i Convertible - 2002 540i/6 |
05-04-2021, 09:02 PM | #4 |
Rep 169
That’s the thing, it’s an on and off smell with no visible smoke ever appearing. I do wanna add I did the oil filter housing gasket but there’s a sh*t load of oil under the manifold and tons of oil covering the front of the engine that I didn’t clean after the OFHG job so that might make it smell burnt up too? I check my valve cover gasket commonly and never found a speck of seepage... It never smells burnt once I open the hood only smells burnt when it’s closed
05-05-2021, 12:27 AM | #5 |
Rep 733
Something may have gotten hotter than normal and exposed a leak or issue, but don't worry about engine wear or anything of the sort. A lot of these cars get driven flat out for 30+mins a day and don't complain...110mph is nothing for one of these.
05-05-2021, 05:05 PM | #7 |
Rep 1,232
Yeah when my dad was end of life last year from a heart attack, I got my brother and my mom to the hospital with an average speed of like 125mph+. Covered something like 60 miles in no time and they got to see him minutes before he passed.
This was last year and the car already had 220K, I was running it HARD and it is still just as healthy as ever. Like other said these cars are designed for that kind of punishment, probably doesn't help you have a mess of oil all over the front end of the car clean it up! |
05-07-2021, 12:12 AM | #9 |
Rep 4,324
05-10-2021, 12:33 PM | #10 |
Rep 169
05-10-2021, 01:12 PM | #11 |
Rep 4,330
I found with my valve cover leak that there was no visible leak at the edge of the cover. it was leaking under the beauty cover and when driven aggressively the oil would spill out of the molded cavity it was sitting in and onto the exhaust.
pull the plastic covers on the top and you'll probably find oil somewhere. |
Jesda144.00 |
05-10-2021, 01:27 PM | #12 | |
Rep 397
Clean'er up and take another 100+MPH jog (in Mexico mind you) and see if the fragrance returns. |
05-10-2021, 09:43 PM | #13 |
Rep 1,530
Or faster if your in Germany on the autobahn!
2021 M40i Phytonic Blue / Black Vernasca
2020 X5 xDrive 40i Tanzanite Blue / Coffee Vernasca 2011 328xi. Space Grey - Sold 188,925 great miles |
05-10-2021, 09:48 PM | #14 |
Rep 2,529
Drives: 2011 328i Wagon
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option '11 128i Convertible - Space Gray on Savannah Beige, 6spd manual, also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire |
05-11-2021, 06:37 AM | #15 |
Rep 269
You did mention you have oil all over the front of the engine, spray it with degreaser and clean it well because your belt with shred to pieces eventually trust me. Also 20 minutes of driving is enough time to warm up and do whatever you want with the car, I'm pretty sure you just warmed up the car more than you usually do by pushing it hard and it's burning some oil on the engine/exhaust
Jesda144.00 |
05-11-2021, 06:55 AM | #16 |
Rep 411
Drives: 2011 BMW 328i XDrive
+1
Clean the old oil up. That way you can see if new leaks occur. Always do this when fixing those pesky leaky areas |
05-11-2021, 06:09 PM | #17 | |
Rep 350
08 E93 N52 170k
