Advice needed - selling for parts, or to junkyard, or donate?
05-05-2021, 09:14 PM | #1 |
Rep 19
Sadly, my 2011 E93 needs about $6,000 in repairs (or a complete engine replacement), which is as much as (or more than) blue book value, so I decided not to have it repaired. (Car is NOT drivable)
Any suggestions on how to deal with getting rid of it? I would like to try and get a grand or two out of it, from someone who wants to part it out maybe, but that might not be realistic. I know I can donate it for a write off or sell to a junkyard for a few bucks, but I'm asking what folks think is the best option. Repairs needed: 1) New valve cover / gasket 2) Replace timing chain, gears, actuators and guides Everything else works great, including the folding hard top. I even spent about $6k on upgrading the audio system many years ago, so perhaps there is value in those components as well, to someone. I'm in NorCal if anyone wants to check it out. Thanks! Last edited by bollwerk; 05-05-2021 at 09:14 PM.. Reason: correction |
05-05-2021, 09:23 PM | #2 |
Rep 1,152
Put info on Facebook market palace and Craigslist. You should get a 3-5k offer as is..if you want to part out you would make more but would have to to do more work and time.. What color is the car??
05-05-2021, 09:34 PM | #5 | |
Rep 1,917
Mosaud19983980.50 |
05-05-2021, 10:28 PM | #7 |
Rep 852
Keep in mind an n52 or n55 can be had running for 1k or so. Buddy of mine just bought an n55 for 800 for his 135 and I've seen tons of n52s for less than that. I think it's worth changing the engine instead of parting it out or selling for a lot less than market value
Airplane Mechanic
BMW Masochist |
05-06-2021, 05:19 AM | #10 |
Rep 18,808
N52. Sorry dude
05-06-2021, 05:20 AM | #11 |
Rep 18,808
OP, any known cause for the timing chain failure?
05-06-2021, 12:36 PM | #13 |
Rep 19
Thanks for the responses.
Answers to various questions: Color - blue Trim - 328i SULEV Engine replacement - while I didn't get an exact quote, I was told it would cost around $8-10k to replace, from the shop I had it at, and this was corroborated by a friend who is a mechanic who has owned and worked on BMWs in the past. Now, of course this assumes a swap with a new engine. I'm not sure I'd want to swap with another old engine, unless it was just rebuilt. I don't have the expertise to do any of this, but if someone else wanted to buy it and do it themselves, more power to them. The shop owner couldn't say exactly why the timing chain failed, but he suggested that with an older BMW, the oil should be changed more frequently than the manufacturer recommends, to avoid sludge, which can possibly contribute to the chain "jerking" and causing bolts to shear. Honestly, it's a fucking gorgeous car and I would hate to see it waste away in a junkyard. I hope I can find a good home for it. Last edited by bollwerk; 05-06-2021 at 12:40 PM.. Reason: added clarity |
05-06-2021, 12:43 PM | #14 |
Rep 7,215
yeah, I kind of don't buy that explanation. there are many N52s with way more miles that follow the CBS. timing chain failure isn't impossible but it's pretty rare. You definitely don't need a *brand new* engine either, but I get it - you don't want to deal with it.
Non-running I wouldn't expect to get much for it, it just depends on how much hassle you want to deal with. Maybe somebody will want to buy it cheap and DIY swapping the engine, but I don't know how in demand convertibles are since it is usually cold and wet where I live.. |
05-06-2021, 12:47 PM | #15 |
Rep 19
Update: This website claims they'll pay me $1835 for it, and tow it away. Better than I expected.
https://www.cashautosalvage.com/sell-my-car/ Anyone gone this route? |
05-06-2021, 01:51 PM | #16 |
Rep 852
Idk but I'll give you 2k
How many miles are on that car? If it's sulev abs under 150k miles you can get all the work done for free under warranty
Airplane Mechanic
BMW Masochist |
05-06-2021, 02:04 PM | #18 |
Rep 901
Right, if it’s Sulev then try to fix it using Sulev warranty. 2011 should be under 150kmiles, I would not sell it to a junkyard until I tried to get it fixed under that warranty. Pretty sure it covers timing chains and other timing components and probably the entire engine. Call some of the better dealerships first, don’t sell it for scrap just yet!
05-06-2021, 06:00 PM | #19 |
Rep 19
Thanks for the tip on the SULEV warranty. I called my local BMW service department. While the valve cover is covered under that, the timing chain is not. If I had it towed over there to fix that, I would still need the timing chain fixed, which would likely cost much more than my local shop, based on my past experience. I'm not sure it would save me much money if they can't fix both under warranty.
05-06-2021, 06:33 PM | #20 | |
Rep 852
I'm sure this is some bureaucratic type thing where they won't cover it if it failed in X way but if it did in Y way it would be covered so if you're going to change the whole thing anyway might aswell try to emulate the failure mode they need to see
Airplane Mechanic
BMW Masochist |
05-06-2021, 07:12 PM | #21 | |
Rep 1,186
05-06-2021, 07:26 PM | #22 |
Rep 815
With all due respect to the OP, it's pretty clear that he just doesn't want the car or the hassle and would rather simply get some cash for a problem that he wants out of his driveway/garage asap. To each their own, and if you've got the resources to do what you want, then more power to you.
So, someone on here who's in the Bay area should make him a real offer over $1800 and get the car. I'd love this as a project myself (always loved the idea of those hardtop convertibles), but as they say, "wrong coast". (plus, I could probably find a similar project out here if I really cared to) FWIW, I also will second the point about the warranty. Serious warranty service - IMO - always requires work on the claimant's part, but it can often pay off. I got a whole new cylinder head on my car due to being persistent about the ticking valve issue (back when the car was still under BMW's extended warranty). I've heard positive stories about the SULEV warranty. But again, I think the OP simply wants the car gone and actually doesn't want to go through the work of getting it fixed. |
E92_William1306.00 |
