05-31-2021, 05:54 PM | #1 |
Rep 373
New M3C Completely Dead
Hey guys like the title says had the car out Sunday was ok car has 350 miles on it went out today to take it out and the key fob wouldnt open the doors got the other key same thing and couldnt use comfort access to gain entry.
Used the physical key and gained entry and no interior lights no red alarm light on the front windshield and the car wont start. Im assuming there has to be a module problem anybody have any insight?? Also the car is in the garage how can I get it towed if the car wont start and cant put the car into neutral and release the parking brake?? Appreciate any feedback guys im obv calling BMW tmrrw but wanted to get some ideas on here cheers
22 G83 X Drive Toronto Red Black Interior
Blue Calipers Frozen Black Edelweiss LT3 |
05-31-2021, 06:02 PM | #2 |
Rep 9,709
That sucks.
The ZF gearbox has a mechanical park release located on the left side. An arm with a screw in it. Screw it in until it releases the parking lock. No idea how you release the parking brake with the electric e brake. Probably a wheels off job. Battery connection ok? Hope you get it resolved soon. |
05-31-2021, 06:20 PM | #3 | |
Rep 373
I checked the battery everything seems to be ok there but reading other BMW models have had problems w the battery cable tp the fuse box Ill see what they say tmrrrw and will update everyone in case they have the same problem with there G8X
05-31-2021, 08:03 PM | #6 | |
Rep 596
- battery is dead (either failed prematurely or something drained it) - connection came loose and just needs to be reattached - alternator is screwed in some way, which allowed the battery to drain I would guess it is 1 and something drained the battery (ignition was left on or something, although they usually turn themselves off after awhile to prevent this happening). Once the battery is dead you really should just get a new one, they're never the same after they go completely dead, even if they can be jumped and recharged |
997CABOVA188.00 |
05-31-2021, 11:46 PM | #7 |
Rep 630
Drives: 2021 G80 M3
Bummer this happened to you. Hope it gets resolved quickly!
Looking forward to the diagnosis. Sounds like a battery as mentioned above but with the amount of electronics in this generation of car who knows… |
06-01-2021, 03:40 AM | #8 |
Rep 27
Sorry to hear this buddy, I had the same issue with a brand new 420i... turned out to be one of the main electrical boards had died. Took BMW 4 week to get the parts to fix, to their credit they gave me a decent loaner.
Hope it is something simple! |
997CABOVA188.00 |
06-01-2021, 05:38 AM | #9 |
Rep 373
Exactly man it could always be worse thanks for the support
06-01-2021, 05:41 AM | #10 | |
Rep 373
Ill see soon enough hopefully Thanks for the help
06-01-2021, 05:42 AM | #11 | |
Rep 373
Thanks man
06-01-2021, 07:58 AM | #12 | |
Occasionally frequent poster
3005
Rep 2,745
In a car this new, it's not worth trying to diagnose and fix yourself, just have them come get it and trust that they will take care of it, hopefully as a high priority (since it is so new). Best of luck to you! Yes, it sucks. But things like this do happen, and the car should be fine.
Current inventory:
F22 & G05 Cadillac CT5-V Blackwing w/3 pedals Past: E24,E28(3),E34,E36,E37,E38(2),E39(4),E46,E89,E92 (obviously),F01,F06,F10,F30,F87,G12,G30(2),G82(2) |
06-01-2021, 08:06 AM | #13 | |
Rep 373
He checked the battery it as indeed dead he jumped it and the lights came on and it started which I was happy to see especially for the tow guy haha Ill update what the dealer finds something is draining it so im sure they will get it figured out Thanks guys for everything
Sbm007613.50 chicagofan0019266.00 |
06-01-2021, 08:42 AM | #14 |
Rep 630
Drives: 2021 G80 M3
Not that you would need it on a new car, but a battery tender is a very small investment to prevent issues like this if you're ever storing your car for long periods of time in the future.
Just make sure you get one specifically for lithium ion batteries! |
06-01-2021, 08:46 AM | #15 | |
1949
Rep 1,908
Drives: E92 M3
Edit: It's not AGM. Last edited by Ximian; 06-15-2021 at 12:42 PM.. |
06-01-2021, 09:23 AM | #16 |
Rep 630
Drives: 2021 G80 M3
06-02-2021, 04:39 AM | #17 |
Rep 919
06-02-2021, 07:45 PM | #18 | ||
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3546
Rep 4,228
06-02-2021, 07:46 PM | #19 |
3546
Rep 4,228
06-08-2021, 09:44 AM | #21 |
Rep 373
Hahaha literally just spoke with my SA theres good and bad news
The bad news is they can’t find anything wrong they ran a scan no fault codes the battery itself is actually healthy they have a safe fail mode and apparently the battery shut itself down so it wouldn’t die. So the food news is they have let the car sit for almost 6 days and it starts right up so maybe a freak thing something was left on Now my question someone mentioned here earlier should I look into a battery tender/charger since this car isn’t my daily?? Thanks guys for the concern |
