06-01-2021, 05:58 PM | #1 |
BimmerPost Supporting Vendor
24366
Rep 191,194
Burger Tuning BMS High Density RACE Replacement Intercooler**NEW PRODUCT**
Deliver consistent, reliable power run after run The last intercooler you'll ever buy for your N55 N20 N26 BMW. Good for over 1000whp the BMS High-Density RACE intercooler delivers better cooling, more power to the wheels, and allows you to hold that power longer during extended runs. With a larger core and more surface area than stock, your intercooler pressure drop is reduced and cooling dramatically improved. Resulting in peak power gains of 10whp+ and during longer pulls and back to back runs as much as 30whp+ over the heat soak prone factory intercooler. BMS replacement intercooler upgrades are a direct replacement for your factory BMW intercooler and fully reversible. All required hardware is included. The new F chassis RACE core is intended for serious performance applications such as upgraded turbos or single turbo kits, providing absolutely the best cooling capacity available in a high quality and high-value package. RACE requires minor trimming of the plastic shrouding during installation. Features and Benefits High flow oversized design Larger end tanks Larger core size Prevents heat soak Direct bolt-on factory replacement APPLICATIONS BMW 1 Series • 2014+ N55 BMW F20 F21 M135i BMW 2 Series • 2014+ N55 N20 N26 BMW F22/F23 228i, M235i, and N55 Powered M2 BMW 3 Series • 2012+ N55 N20 N26 BMW F30 F31 F34 320i, 328i, 328ix, 335i, 335ix BMW 4 Series • 2014+ F32 F33 F36 N55 N20 N26 420i, 428i, 435i, 435xi Coupe, Convertible, and Gran coupe
06-01-2021, 08:01 PM | #4 |
24366
Rep 191,194
Close in dimension, Wagner EVO III is a lot lighter because its tube and fin.
This intercooler is bar and plate.
M2OG400.00 |
06-02-2021, 01:00 PM | #6 |
24366
Rep 191,194
They look similar but this intercooler is a much larger than CSF
