06-15-2021, 05:31 AM | #1 |
Rep 50
Unusual behaviour from stock B46 engine
So I'll preface this with the fact that my car has had…a lot replaced due to issues caused by the engine wiring harness TSB so maybe other electrical or similar issues shouldn't be so surprising.
I've noticed that during spirited driving and once or twice on the highway that my car has very strange rev hang (even at lower RPM) and a big drop in torque at about 5000 rpm or so. I figured it may have been due to heat soak on the spirited drives but all temps were well within the norm. These two codes especially seem to come up quite a lot: 10D000: Combustion engine: torque limitation active 24000B: Timeout data EWS Any suggestions would be much appreciated! Hoping to avoid yet another dealer trip. |
06-15-2021, 11:08 AM | #2 | |
Petrolhead
1943
Rep 3,521
Regarding rev hangs. I haven't noticed it but you might be right. I'll pay more attention and report.
Current:
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige |
06-15-2021, 06:45 PM | #3 | |
Rep 380
VipinLJ1943.00 |
06-15-2021, 07:00 PM | #4 | ||
Rep 50
I'm still not 100% sure it isn't some kind of limp mode from heat soak, but all temps, pressures etc looked normal in the logs. |
06-28-2021, 02:33 AM | #5 | |
Rep 50
I asked Halim who's the tuner of Bootmod3 for this and he said it was due to OEM torque limitation. |
06-09-2023, 12:15 PM | #6 |
Rep 58
Do you know if XHP will fix this? I keep getting the same shadow code “10D000- Combustion engine- torque limitation active” when trying to datalog WOT on my e-85 map, and it pulls timing bc of the torque limitation code Im guessing. It holds timing on partial throttle so I hope xhp will fix my issue with the timing pulls.
06-11-2023, 11:59 PM | #7 | |
Rep 58
